IDE Source control Plugin etc..
I am using CVS now, although if Parallax has some time, this would be a nice feature for the IDE, as I think we all agree that the prop is no longer jusst a "hobby" chip like the BS2. Its price comparable with some of the Pic's out there now and can do alot more than most. I also would like the Chip to be able to read a write protected eprom and the IDE burn one is this already possible to burn an eprom instead of the using the current·eeprom and still have the prop load it? then firmware updates would require a new eprom, and hacking of commercial prop devices would be somewhat protected especially after you break pins 30 and 31 off and or seal the qdip in a pvc blob.
That said I have 'potted' various MCU,eproms & eeproms in the past- swapping pinouts etc on custom P.C.B·to protect against copying. Makes firmware updating easier.
Quattro
