Controlling a CDROM motor with a BS2
Hi - Has anyone setup a BS2 for controlling CDROM motors? By chance have a link showing how to do it?
I pulled out a brushless motor out of my CDROM drive. I want to use the BS2 for the controller.
THanks
THanks
- Stephen
The brushed being 2 wire and the brushless being 3 wire. Not sure how to control it with the BS2.
www.ewh.ieee.org/soc/es/May2001/02/Begin.htm
- Stephen
This (link below) should give you an overview of brushed vs. brushless motor controllers. I suspect you will need to use a brushless motor control chip if you want to use PBASIC and a BS-2.
http://www.siliconfareast.com/motor-controllers.htm
Bruce Bates
<!--StartFragment -->
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
Can find things for DC and Stepper controllers but not a lot on fabricating my own brushless controller.
