Controlling a CDROM motor with a BS2 — Parallax Forums
studysessionstudysession Posts: 66
edited 2007-02-05 20:48 in BASIC Stamp
Hi - Has anyone setup a BS2 for controlling CDROM motors? By chance have a link showing how to do it?
I pulled out a brushless motor out of my CDROM drive. I want to use the BS2 for the controller.
    edited 2007-02-03 17:35
    If it's a brushless DC motor I would think it would work just like any other. There are many threads on controlling motors here. It also depends on what you want to do with that "control"
    - Stephen
  • studysessionstudysession Posts: 66
    edited 2007-02-03 17:42
    I did some searches and was able to find great info on brushed motors and how to control them. But not how to use the BS2 controlling a brushless motor.
    The brushed being 2 wire and the brushless being 3 wire. Not sure how to control it with the BS2.
    edited 2007-02-03 17:57
    You are right, they are not as easy to control as a brused version. Here's a link that may help (or at least confuse you more)
    www.ewh.ieee.org/soc/es/May2001/02/Begin.htm
    - Stephen
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2007-02-03 18:11
    StudySession -
    This (link below) should give you an overview of brushed vs. brushless motor controllers. I suspect you will need to use a brushless motor control chip if you want to use PBASIC and a BS-2.
    http://www.siliconfareast.com/motor-controllers.htm
    Bruce Bates
    <!--StartFragment -->
  • WarrlokWarrlok Posts: 77
    edited 2007-02-05 15:37
    I thought CDrom drives had stepper motors ,,,, u shure its a brushless ? you could use a R/C brushless speed controller not gonna work as good as a MC like HB-25 or the Sabrertooth,,
    Problems are the "roads" of life,
    solutions are only "onramps" to the next problem
    ············································· "Brad Smith"
    Yes it is brushless. I have RC brushless controllers. I really want to learn how to build one though so been trying to find stuff ont hem.
    Can find things for DC and Stepper controllers but not a lot on fabricating my own brushless controller.
