Home-Work Board USB problem
Hi,
I am having problems getting my mac to recognize the HomeWork Board. I am using a Serial to USB converter. Can this work?
Thank You,
Tyler
Thank You,
Tyler
If you mean USB to Serial adapter, you must use a compatible unit and have the correct drivers for it installed. The FTDI-based units we carry seem to work for many of our Mac users. The FTDI website has the Mac drivers available. Take care.
Chris Savage
Parallax Tech Support
I will try the FTDI site again, if it doesn't work I'll be back with mor questions.
Tyler
Just so you all know and probably already do, the Radio Shack USB/Serial adapter, and the Belkin adapters do not work for Basic Stamp on a mac. I had to order a Keyspan USA-19hs. If this was a miss-guided purchase let me know.
Tyler
BudW
I noticed yesterday that there is a new Keyspan Driver for Intel Macs (2.27, I think) I downloaded it and, While I was at it, I downloaded the newest version of MacBS2, which recognizes my adapter as one that is known to work.
All is good. Now I don't have to drag out the laptop.
If you have an Intel Mac, that may solve your problem. Even if you don't, the newest MacBS2 may help.
Now, If I can get the Prop Tool to work on it...
So do I understand correctly that a Belkin adaptor will not work, even on a PC? Loopback and Echo both read "yes," but it doesn't recognize any device as being attached.
I just got the Keyspan; it works great. I spent a lot of time trying to get other adapters to work. It is not worth the effort unless you are writing a research paper on adaptability.
Tyler
