Current Consumption of Parallax PIR Sensor
Hey,
Does anybody know the current consumption of Parallax PIR Motion Sensor?
Funny the datasheet does not specify it.
I need to use it for a battery powered project.
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
The datasheet is being updated today and will reflect that information. To answer your question current draw is approximately ~100uA. Unfortunately my meter has trouble with extremely low current measurement (<1mA) so this is close. The PIR will operate at 3.3V as well. Check over the next two days for updated documentation. Take care.
Chris Savage
Parallax Tech Support
The PIR was jumpered for Active LOW. But when jumpered for Active HIGH I read the same readings.
This is real world measurements at 5v, with a fairly expensive and accurate meter that has up to 200u accuracy.
I used a 10k resistor between my SX microcontroller's input pin and the output pin of the PIR to tell when the PIR was in a triggered state. The microcontroller turned on a LED when the PIR sensed motion.
Meh. Nothing here, move along.
Chris Savage
