Since all I/O pins are input by default you could just use OUTPUT 0 in your code or, if you know the default state you want the pin to output at you could use HIGH 0 or LOW 0 which will make the pin an output in that state. The rest will remain inputs. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
- Stephen
Have Fun
TR
- Stephen
Chris Savage
