Prop-1 inputs and outputs — Parallax Forums
haunteddansionhaunteddansion Posts: 68
edited 2007-01-27 23:05 in BASIC Stamp
How do I initialize the program so·pin 1-7 are inputs, and pin 0 is an output. What would the code looks like thanks much!
    edited 2007-01-27 02:50
    I think it's something like dirs %10000000
    - Stephen
  • TechnoRobboTechnoRobbo Posts: 323
    edited 2007-01-27 19:10
    dirs %00000001
    Have Fun
    TR
    edited 2007-01-27 19:16
    - Stephen
    Hello,
    Since all I/O pins are input by default you could just use OUTPUT 0 in your code or, if you know the default state you want the pin to output at you could use HIGH 0 or LOW 0 which will make the pin an output in that state. The rest will remain inputs. Take care.
