Alternative Rs232 propeller Interface
christopher
Hi,
I have built and successfully used the three transistor interface circuit for the propeller featured on this site. However, when I use the same circuit from a separate cog, I am finding that the when the circuit is connected to the PC with the pc tx driving at -10 volt it works fine but when disconnected from the PC it seems that the cog detects a low going pulse and this traps the cog as it waits for further serial data input.
Has this been experienced and does max3232 solve this problem ? Can the problem be solved with discrete transistors ?
Thank You
Chris
Thank You
Chris
Chris
At low speeds (19.2KB or less), you could start with the Simple_Serial driver which is all in Spin.
Try the attached serial driver. I added some code to the receive routine that checks at 1/4 bit time and 1/2 bit time from the leading edge of the start bit. If the serial line is high, it wasn't a start bit really and the routine waits for the next high to low transition. I haven't tried the routine, but it should work as modified.
Post Edited (Mike Green) : 1/18/2007 3:25:55 AM GMT
Many thanks for your assistance I shall implement same. Allow me to allow take advantage of your good nature. I am in fact using the simple-serial.spin at 4800 baud, but the routine awaits a start bit. I would like to implement a time out in the event that the remote pc does not deliver after a specified time. Is there such a routine or should I·adjust simple-serial to timeout and return.
You've just helped a guy in Trinidad· W.I (yeah it's warm)
Chris
It is possible to do the same kind of thing with the simple serial routines (make the receiver and transmitter run in a separate cog with a simple buffer), but the FullDuplexSerial object already has been written and works well.
Again
Chris
I have a stepper board set up with a motor so that I can send serial strings to it through Windows Hyperterminal and have it do things. These strings are very simple. For example, I can send it "+s" (slew) and the motor will just start spinning until I send it "z," which will stop it. Great. Now it's time to get Propeller to do it.
The board has a Serial In pin, and I have gleaned that I can try to use Simple_Serial or maybe FullDuplexSerial (overkill? I'm not rx-ing at all yet!). In this scheme, I should just make sure both boards are sharing ground and then connect the Serial In pin to some pin, say pin P1 on the Propeller Demo Board, call Simple_Serial simply, and send it the string to send. So I've tried it, and it isn't doing anything.
Any advice? Did I miss an important concept? Here's all of the code I think it should take. If anyone can straighten me out, I'd really appreciate it.
' testing simple_serial
' need to make an object to start it
' then send it the string...
obj boardcom: "Simple_Serial"
Pub start
· boardcom.start(-1,31,9600)······· '(rx pin, tx pin, rate) -1 for fake rx
· boardcom.str(string("+s"))········'send slew command
Alex
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
ExtSerial : "FullDuplexSerial"
Pub Test
· extserial.start(8, 7, 2, 9600) ' rxpin,txpin,mode,Baud - depends on your set up
repeat 10 ' repeat 10 times
· extserial.str(string("+s")) 'slew
· waitcnt(20_000_000 + cnt) 'wait a length of time while slewing
··extserial.str(string("z,")) ' stop I PRESUME THE COMMA IS INTENTIONAL in your example
· waitcnt(20_000_000 + cnt) 'wait stopped for a while
if CR - carriage return is required after the command -·mod the line of code this way
extserial.str(string("+s",13)) 'slew
or 10 for line feed..
Let me know how you get on..
- yeah just typed it in so corrected now
Post Edited (QuattroRS4) : 1/26/2007 4:52:31 PM GMT
I tried it, without my typo comma, and it was down a couple of ")", but got that worked out easily. No result, though, so I need to check on my mode, and if I'm set up right on the other side. Have you used this board before, by any chance?
I appreciate the help. Wish I saw it last night!
try adding CR & LF
extserial.str(string("+s",13,10)) 'slew
I had a silly interface before that required LF then CR maybe worth bearing in mind.
Did you SEND to hyper terminal from prop - to see if you are outputting OK ?
Doing that you can work out the mode that suits you best - mode 2 for me on laptop - Have also used mode 1 on other machines.
Let me know how you go...
Actually it is a ST microelectronics example 3v -5.5v type - see attached pdf.
Follow the link to the prop stick to see connections -
http://www.parallax.com/dl/docs/prod/prop/PropStick-v1.2.pdf
Post Edited (QuattroRS4) : 1/26/2007 5:19:14 PM GMT
Alex
Used a breadboarded prop with 232 driver as mentioned and traditional 'null modem' (3wire) serial cable - rx,tx,gnd..
Have used it without support I.C· - no problems to traditional serial port (resistors are recommended) - but find that without the driver - I have had issues with some USB to serial devices ...
Quattro
Post Edited (QuattroRS4) : 2/6/2007 1:51:45 AM GMT
Personally I would prefer to use a 232 driver - but further to your query -
I ran a trial just now for you - using a demo board - to a laptop which has a third party usb to serial device as its serial port.
connections as follows - Vss on demoboard to pin5 (gnd) on p.c serial port
P0 on demoboard through a 4.7K resistor to pin 2 on P.C serial port
On the pc start up hyperterminal - 9600,N,8,1 and flow control 'None'
Do the following with the Propeller IDE -
CON
OBJ
Pub Test1
extserial.start(-1, 0, 2, 9600) ' (transmit only)- rxpin,txpin,mode,Baud - depends on your set up
repeat 5 ' repeat 5 times
· extserial.str(string("Hello World 'concatenating' "))
· waitcnt(100_000_000 + cnt) 'wait a length of time
extserial.str(string(13,10)) 'move to new line
repeat 5
· extserial.str(string("Hello World in a new line each time!",13,10))
You should see the results in hyperterminal window.
You may have to adjust the 'Mode' to suit your needs .... mine worked in both modes 2 and 3
Let me kow..
Quattro
Post Edited (QuattroRS4) : 2/6/2007 7:57:10 PM GMT
