Best way to attach a motor to a pulley? — Parallax Forums
latigerlillylatigerlilly Posts: 114
edited 2007-01-24 23:14 in Robotics
Hi guys,
How do I attach a motor to a pulley?
I am thinking, just put the belt around the motor drive shaft and put the other end of the belt around the pulley. The pulley is attached to another shaft by a set screw. This shaft is connected to a ball bearing with a set screw. This same shaft is also has 2 shaft collars that have set screws. Squashed between the shaft collars is a bicycle tire. This is the best I could come up with. It seems pretty flimsy to me. Any better ideas?
Direct drive with a overamperage protection circuit seems the easiest, but, again I have no idea how to connect the wheel to the gearmotor drive shaft.
I am using the Parallax HB-25 controller and this 12 VDC 212 in-lb gearmotor:
http://robotcombat.com/marketplace_motors_ame.html
Lilly.
    edited 2007-01-24 06:59
    latigerlilly,
    I would think, that a chain-drive would be better suited for this type of application. It would certainly introduce less friction and reduce any slippage that might occur if a belt drive were used. A local bicycle repair shop should have, or know of a source for a sprocket that would fit to the motor if it's not a standard shaft diameter.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-01-24 21:46
    Beau, according to her other post she is using a pully system to allow for slippage in case the wheel stalls it won't stall the motor.
    latigerlilly, look into a device called a 'pillow block. they would support the shaft on both sides of the wheel giving it the support you need.
    - Stephen
  • ZootZoot Posts: 2,227
    edited 2007-01-24 21:56
    Robot Marketplace carries pillow blocks and all sorts of shaft bearings/couplings. If memory serves, that's where you purchased the motors? You might also try contacting them and see if they have suggestions/parts for mounting the kind of drive pulley you want on the to the shaft of the motor.
  • allanlane5allanlane5 Posts: 3,815
    Typically, you attach a pully which has the right inside diameter on the shaft of the motor. Typically, the pully has a 'lock screw' to lock it to the shaft.
