Fixed a HUGE problem involving inplace effected memory (interpreted)
x /= y was being processed as x := y / x (Which is bad).. Order of operations is now appropriate
Changed the name of BusModule to PluginBase (makes more sense to me)
Sped up the interpreted core a little bit (doesn't use the stack for internal temporary variables)
Cleaned up the source significantly
Fixed a minor bug in the composite video generator phase shifting code (s-video)
Numerous bug fixes scattered about the native and interpreted cores
It still doesn't want to work in mono, I managed to get it to compile in mono, but it threw a fit when I tried to run it.
Ym2413a said...
Cool! I'm glad you added the monitor plugin!
I wanna' play with it now.
It's not perfect , but it's getting closer with every release. HSS manages to produce some form of PWM audio (it looks like it's ~80% volume solid out the speaker) I don't know if it's just producing silence before it plays audio, or if it's emulation glitching. The later is probably the case, since the TV driver never actually sets any pins out output, and locks in WAITVID.
Yeah, but it's still amazing work even though its not done. ^^
I think GEAR could really be something great.
(Hss) output should be 50% PWM on start after a quick 0 PWM pulse during the audio COG's bootup.
I'm looking forward to working with the Propeller some more, since I wasn't able to do anything the past few days.
You guys don't know how much it means to hear praise on my project. The last 5 minutes have been pretty one big mood boost after another. [noparse]:)[/noparse] (Check the screenshot from what I managed in the last few minutes)
Post Edited (asterick) : 1/23/2007 12:56:50 AM GMT
Well I played around with GEAR and (Hss).
It really seems to run the code faster and better then I thought it would!
Althought it didn't produce the correct PWM output. (It stayed at 75% duty and wouldn't update)...
The sound engine's code seems to jump around correctly!
The branching order seemed fine and all parts of the program where getting hit correctly.
So if anything it has to be a little bug for why it's not running.
I'm pretty sure the bug has to do with the native core. The interpreted core does well with just about everything I've thrown at it. I'm going to try hand verifying all your instructions and see if I can get it to output audio (and it was 15/16th duty, I double checked. [noparse]:)[/noparse]
I'm trying to stick with VGA and HSS based applications since they are the easiest for be to verify the output of. (the propeller doesn't have that many instructions, so it's really only a matter of time)
Yeah, it is only a matter of time before this becomes a great development tool for the Prop. (lol)
I'm going to write a few smaller PWM test programs and run them thru GEAR for testing reasons to find where these little bugs are.
Who knows, It might just be a weird little bug or something. I'm going to help get to the bottom of this!
I now buffer the video settings at the start of a WAITVID call (both VCFG and VSCL, which is probably waaaay wrong). I'm starting to think what the propeller does is loads a counter with PixelClocks when it is counting down a pixel, and when it reaches zero, it reloads it... same thing with frame clocks.
Also, I've changed the way that ?x and x? works in the interpreter, it's much more random, and closer to what the actual propeller would do (negative feedback LSFR)
Also, when the entry function of a cog returns, it stops itself, rather than reboots the propeller now (nessessary for some of the demo applications)
There have been a few timing adjustments, and bug fixes, once I get more stuff working, I'll update again.
Well, I think I squished one of the last BIG bugs in the native mode cog core... and I'm a right idiot for not noticing it before hand.
I do delay latch on the results of various operations, for the sake of compatibility. Essentially, a operation executes, and stores it's results in 3 different values which are copied into their final destinations. This is all well and good, except those values are not preinitalized, for the sake of speed, since every instruction sets carry / zero / result to SOMETHING. Every instruction except something that is not supose to execute. This resulted in a rather unforunate incident where operations where conditions were not true were writing values to places that they should not have been, which resulted in things clobbering values with trash.
New release (1.5.0.0) is up, quick coverage of the changes (that I remember):
Proper handling of condition field on native instructions
VSCL is now buffered between WAITVID frames (VCFG is not)
Changed behavior of Forward and Reverse random (negitive feedback LSFR, rather than rotating buffer with XOR)
Timing fixed on instructions
Fixed parity and other various instruction flag issues
A cog stops rather than reboots the chip if the interpreter returns from it's starting function (stack underflow)
Increased the size of the virtual VGA monitor plug-in (Bitmap 512x384 VGA runs at 1024x768 with pixel / line doubling)
Included a PinNoise plugin, which plays with some pins.
PLLs dejitter is now more accurate (uses sub-system clock accuracy)
I've been following your project with interest. I've been too busy take your program for a spin, but I can tell by your screenshots that you're doing a bang up job.
Something I overlooked in the thread, can it work with assembly code as well? Have you thought of implementing some pattern matching to generate IDE-like spin code?
Well I appreciate the interest. [noparse]:)[/noparse]
The emulator currently emulates every aspect of the propeller except broadcast video generation because I don't know how that works. (baseband is in there though). So yes, it does do assembly, as well as interpreted.
As far as the pattern matching, I'm avoiding doing any logic like that if I can, since the compiler's output could change in a future revision, and still be bytecode compatible. what I'm hoping to do is implement a .spin loader / compiler (MAYBE) that will create a map for the source file and let people step through that way. It's a LONG ways off though. I want to make sure the emulation is accurate, then work on all the extras like that.
Who knows, maybe you kids will make a line tab file output for me. [noparse]:)[/noparse]
Whenever I try to open a binary (even one of the simple examples from the manual),
I get the following error.
System is an US WinXP professional SP2, CeleronD 1.6 GHz, 512MB RAM
Any ideas?
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Gear.GUI.CogViewer.Repaint(Boolean tick)
at Gear.GUI.CogViewer.AsmSized(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height)
at System.Windows.Forms.Control.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
at System.Windows.Forms.Control.ScaleControl(SizeF factor, BoundsSpecified specified)
at System.Windows.Forms.ScrollableControl.ScaleControl(SizeF factor, BoundsSpecified specified)
at System.Windows.Forms.Control.ScaleControl(SizeF includedFactor, SizeF excludedFactor, Control requestingControl)
at System.Windows.Forms.Control.Scale(SizeF includedFactor, SizeF excludedFactor, Control requestingControl)
at System.Windows.Forms.Control.ScaleChildControls(SizeF includedFactor, SizeF excludedFactor, Control requestingControl)
at System.Windows.Forms.ContainerControl.Scale(SizeF includedFactor, SizeF excludedFactor, Control requestingControl)
at System.Windows.Forms.ContainerControl.PerformAutoScale(Boolean includedBounds, Boolean excludedBounds)
at System.Windows.Forms.ContainerControl.PerformNeededAutoScaleOnLayout()
at System.Windows.Forms.ContainerControl.OnLayoutResuming(Boolean performLayout)
at System.Windows.Forms.Control.ResumeLayout(Boolean performLayout)
at Gear.GUI.CogViewer.InitializeComponent()
at Gear.GUI.CogViewer..ctor(Int32 host)
at Gear.GUI.Emulator..ctor(String source)
at Gear.GUI.GearMain.OpenFile(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Didn't fix the problem, but now it takes longer before the exceprion appears.
I have .net 2, including SP1.
And I've already tried reinstalling it.
at Gear.GUI.MemoryView.Repaint(Boolean tick)
at Gear.GUI.MemoryView.SizeChange(Object sender, EventArgs e)
at Gear.GUI.MemoryView.InitializeComponent()
at Gear.GUI.MemoryView..ctor()
I don't think that there is something wrong with the .net framework,
as other programs run fine (paint.net as an example).
Not to mention my own programs, because I use visual studio.net.
at Gear.GUI.LogicProbe.OnSized(Object sender, EventArgs e)
at Gear.GUI.LogicProbe.InitializeComponent()
at Gear.GUI.LogicProbe..ctor()
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
The line numbers are not that big of a deal, I know why these exceptions are happening, I changed the way the internal tabs (which are now built around the plugin system) and I forgot to add the conditions to make sure that the object was presented with the emulator. For some reason, my machine doesn't perform any of the repaint stuff until AFTER it's been given the emulator, so I never thought to fix it.
Although, Kloss, could you truncate down to like 4 lines in the exception text from now on? those traces are a little long.
I'm currently smack dab in the middle of debugging like 4 asm instructions, so I'll post a new debugged version soon.
Looking at your error trace, it has something to do with form components not getting initialized. The only thing I can think is that is the result of GDI+ not being up to date (IE: You are not running SP2)
I would recommend you do that, but you can always run this executable, it's a debug build.
It includes a fix on CMPSUB (which is probably still incorrect)
I don't know if that's correct, but it didn't work at all last time. Before, it always subtracted source from destination. Which tried to drive the video PLL at 0.6Hz for the video generator (which it didn't like)
It's not perfect
We'll see I guess. [noparse]:)[/noparse]
--Andrew Arsenault
-tom
--Andrew Arsenault
This fixed a few problems.
Paul Baker
Paul Baker
Post Edited (Paul Baker (Parallax)) : 1/24/2007 2:49:24 AM GMT
Any ideas?
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Gear
Assembly Version: 1.5.0.0
Win32 Version: 1.5.0.0
CodeBase: file:///F:/Propeller/Gear/Gear-1.5.0.0/Gear.exe
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
This might fix your problem. ^^
I'll look into it, thanks for giving me the trace back.
I attached an updated executable, it should fix it (I wasn't checking to see if the emulator was initialized yet)
mscorlib
Gear
System
System.Drawing
I've put as many "emulator not initialized" checks in as possible, should work better now.
mscorlib
Gear
System
System.Drawing
Right now, it works like:
if (DestinationValue >= SourceValue) { DataResult = DestinationValue - SourceValue; ZeroResult = DestinationValue == SourceValue; CarryResult = true; } else { DataResult = DestinationValue; ZeroResult = false; CarryResult = false; }
[color=black][color=black]' z=1: ?x [/color][/color][color=black][color=black]' Z=0: x?[/color][/color] [color=black][color=black] min x,#1 '?var/var? [/color][/color][color=black][color=black] mov y,#32 [/color][/color][color=black][color=black] mov a,#%10111 [/color][/color][color=black][color=black] if_nz ror a,#1 [/color][/color][color=black][color=black]:rndlp test x,a wc [/color][/color][color=black][color=black] if_z rcr x,#1 [/color][/color][color=black][color=black] if_nz rcl x,#1 [/color][/color][color=black][color=black] djnz y,#:rndlp[/color][/color]
I asked about the line tab file and he said the way the compiler is organized it wouldn't be a trival task to generate a line tab file.
Paul Baker
Oh, and I added something 'new' to the logic view, mostly for my benefit... but it's nice to have none the less
EDIT: Nice use of parity by the way. [noparse]:D[/noparse]
