Tele Op Boe
Here is a somewhat complete project.
I made a labview controlled Tele Op Boe Bot. The bot has a ping sensor on a servo which can return a 180 degree scan to labview via the bluetooth mod. Now I want to make it track where the bot has gone. Maybe some mapping an autonomy but I find the ping sensor to be to innacurate on surface at an angle to the sensor. Wish I had a laser scanner. The next big step will be to add a wireless camera to the system and make it truely controllably in the teleop mode and try to do some advanced vision algorithms. But we shall see what time will permit. (Also im going to add missles!!)
If your interested in Labview you can always get it free off of bit torrent.
Muahdib
IC layout designer
Austin Texas
However, there is the CMU-Cam, which can send 'digested' data back to the BS2. But full-motion video, no way.
