how much over 5 volts can the sx handle
What is the margin when it states 5 volts.· I have a regulated 5v 2amp transformer tht is puting out 5.09 to 5.11 volts.· can i connect this directly?
It's Only A Stupid Question If You Have Not Googled It First!!
-Ben
I have also used 4 AA batteries directly on a SX20SS without any regulator and it also survives well.
Of course it is not advisable but sometimes you need to do it.
For example, by not using a regulator, the SX20 can go into sleep mode and drain only a few microamps.
If a regulator is installed, more than a thousand microamps would be drained for nothing.
Another reason to use 6v directly on the SX is when I need to drive a Mosfet's gate like the IRF530 which needs 6V, without the cost of a mosfet driver.
www.fd.com.my
www.mercedes.com.my
