how much over 5 volts can the sx handle — Parallax Forums
Brian CarpenterBrian Carpenter Posts: 728
edited 2007-01-23 03:30 in General Discussion
What is the margin when it states 5 volts.· I have a regulated 5v 2amp transformer tht is puting out 5.09 to 5.11 volts.· can i connect this directly?
It's Only A Stupid Question If You Have Not Googled It First!!
  • BenoitBenoit Posts: 47
    edited 2007-01-12 06:32
    The SX28AC datasheet v1.6 on page 41 specifies a max Vdd of 5.5v.
    -Ben
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2007-01-12 06:36
    ok great than i am looking good.
  • tommytommy Posts: 84
    edited 2007-01-22 23:07
    If the power supply is close but questionable, a 5.1v or 5.5v zener diode placed right after it would shunt any high points to ground...
    edited 2007-01-23 03:14
    thank you. i have implemented the power supply and it works great.
  • william chanwilliam chan Posts: 1,326
    I have used a 7806 6V regulator on the SX28DP and it seems to survive quite well.
    I have also used 4 AA batteries directly on a SX20SS without any regulator and it also survives well.
    Of course it is not advisable but sometimes you need to do it.
    For example, by not using a regulator, the SX20 can go into sleep mode and drain only a few microamps.
    If a regulator is installed, more than a thousand microamps would be drained for nothing.
    Another reason to use 6v directly on the SX is when I need to drive a Mosfet's gate like the IRF530 which needs 6V, without the cost of a mosfet driver.
    www.fd.com.my
    www.mercedes.com.my
