still no loopback and no echo
I purchased the HomeWork Board, and I still can't get it to work. I've tried everything. I checked serial connections, the first 9V I was using turned out to be dead, so I used a different one and that time the LED came on, but still no luck communicating. So then I changed the FIFO buffer thing. Still no good. Any suggestions?
No LOOP BACK or ECHO could indicate a bad cable, Serial Port or that you’re using an incompatible adapter of some sort. Is the PC a laptop or desktop? Are you using the supplied cable to connect it? Are there any adapters or USB converters being used?
Chris Savage
Parallax Tech Support
Chris Savage
Which operating system are you using, and which version of the PBASIC Editor/IDE?
Bruce Bates
<!--StartFragment -->
Chris Savage
I'm using the two available COM ports that I have, which are both detected by my PC.
Chris-
I'll take that into consideration, I've spent too much money already on this project and I don't have any spare serial cables, so I'll have to borrow one from someone. I'll get back to you on that.
Chris Savage
