H48C tri-axis question
Hi, I have an H48C that I've breadboarded onto a homework board and am having problems. When I first fired it up with the sample
code only 2 axis were showing any change. Now all I get is a -4 G reading on all 3 axis. Any suggestions. I don't believe it got zapped with static but unless I'm overlooking something obvious that is the only solution I can think of.
Any help will be appreciated.
Wayne Hilliard
Wayne Hilliard
- Stephen
Hookup wire jumpers used for connections. It's so straight forward that I just don't know. The reference voltage does read properly with the example code.
Wayne
Dave
Dave Andreae
Parallax Tech Support·
