Re: Serial connection problem with Board of Edu Rev C Board BS2 stamp (Boe Bot)
I can't find an answer to this on the parallax web site.
I have a USB to Serial conversion cable. Device driver in Windows XP SP2·shows connection working as COM4.
When I try to ID the board from the BASIC STAMP Editor (Vers 2.5) I receive Loopback No Echo Yes but the board is not recognised.
Do I need to change the serial settings?
Anyhelp would be appreciated, as I'm stuck at the moment.
If this doesn't work I may have to splash out on the bluetooth option. Unfortunately I'd also have to get a bluetooth receiver.
Post Edited (stewjw) : 1/14/2007 12:54:13 PM GMT
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
