Communication Distance
How far ....can a computer communicate with a BS2?
I'm wondering the longest wire length that is reliable.
James L
James L
On how fast, how much noise, if you're just trying to use the 5 volt signals or have some type of line driver, how twisted or not the wire is, etc., etc.
You can also use various forms of RF devices, or something like a PINK to put things on a network.
Assuming you are talking about just using SERIN and SEROUT with the 5 volt signal, I would think you could get at least several feet, and probalby 25 feet or more, if the environment wasn't too noisy.
It will also help if you twist the wires, this helps cancel out noise that the wires would/could pick up from "the ether" (not ethernet, but "the ether" of alchemy).
John R.
8 + 8 = 10
Beau Schwabe
IC Layout Engineer
THey were all helpful.
James L
