Trying to shoot a ping pong ball..
Im trying to launch a ping pong ball from a robot for my sophomore engineering class.· I want to strike the ball, much like a golf ball return mechanism in a putting cup works. My question is, is that a solenoid motor, and if not, what is it.· Thanks
It may well be a solenoid, but I'm not familiar with the term "solenoid motor". I am familiar with a rotary solenoid, but that seems unnecessary in this application.
Bruce Bates
<!--StartFragment -->
Jeff T.
The servo is then moved back into the 'load' position for the next shot.
Anothe solution is to use a solenoid -- a piece of steel with springs inside a coil. When you energize the coil, the piece of steel shoots to the middle of the coil -- and the far end can contact a ping-pong ball. This can take more instantaneous current than the servo approach, however.
my design is going to have a large capacitor charge up, then to launch discharge through a SCR (silicon control rectifier) into the solinoid.
the circuity is fairly simple and I tested a NTE5463 driven directly off a stamp2 and it seems to work (haven't tested with a solinoid yet as I have to build it)
I also tested it with a opto-isolator setup, (a set of radioshack IR led and phototransistor) to prevent the stamp getting surged from the high power discharge.
if you want I can draw up a simple schematic.
--Unstable
If interested, I can get you catalog numbers while at school
have a fun day
Josh
Just noodlin'
Truly Understand the Fundamentals and the Path will be so much easier...
