prop plug design in eagle
I designed my prop plug in eagle and I wanted you guys to take a look at it before I start etching the board. This is only the second board I have tried making with eagle so I have done something that don't look right let me know. Also on the usb connector, I bought usb mini-b connectors to use but I cannot find the footprint for it anywhere. Does anyone know where I could find either them for eagle?
It's a female type A connector, just like your computer has. Then I use a Type A male to Type A male cable to plug it into my computer.
It's a through hole part and the jack can be purchased at most suppliers for a reasonable price, I got mine from Mouser for 92 cents. The Amp part number is 787616
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
I had a look at your board, but I would recommend you to re-route it, you will get some problems if you etch it.
1. the vias under the FTDI chip, there is not much space under the chip
2. the bottom wire to C3, it's difficult to solder it at bottom and top
3. the footprint of the FTDI is very small, keep more space between the GND and the pins (try to use a GND-plate ->polygon)
tip: try to rotate the ftdi chip 90°, i think you can get it single sided with a few vias.
USB connector libs:
tp.cadsoft.de/eagle/userfiles/libraries/con-usb.lbr
tp.cadsoft.de/eagle/userfiles/libraries/con-usb-2.lbr
the libraries:
www.cadsoft.de/cgi-bin/download.pl?page=/home/cadsoft/html_public/download.htm.de&dir=eagle/userfiles/libraries
gtz
eric
