SMD JEDEC Designations — Parallax Forums
TomSTomS Posts: 128
edited 2007-01-06 16:32 in Propeller 1
I would greatly appreciate if someone from Parallax would please give me the JEDEC designations for the two
Propeller SMD chips. I want to make absolutely sure I have the proper pad
layout before I have boards made. I think it would be a good idea for Parallax
to provide a recommended pad layout on your website for all of your SMD chips.
Tom
    edited 2007-01-05 10:29
    The info you need has been posted here: http://forums.parallax.com/showthread.php?p=598127
  • TomSTomS Posts: 128
    edited 2007-01-05 10:42
    Thanks Phil,
    I need the QFN also. When do you think it will be posted?
    Do they have JEDEC designations? I can generate the patterns if I have JEDEC desg.
    Tom
    edited 2007-01-05 18:25
    Tom,
    The QFN land pattern is the first one posted in the thread I gave you.
  • Tracy AllenTracy Allen Posts: 6,658
    edited 2007-01-05 20:30
    I've never found a JEDEC designation for that package. QFNs are relatively new territory, I guess. On the QFN package, be sure to note that the solder paste layer is a little different from pads layer. The paste on the center pad is divided into 4 sections that cover 50% of the pad area.
    Tracy Allen
    www.emesystems.com
    edited 2007-01-05 21:42
    Tracy is correct, the center ground pad should be 50% covered with paste by design of the stencil. 100% coverage "floats" the part during reflow and there is greater likelyhood of non-contact of the pins to thier pad.
    Paul Baker
    edited 2007-01-06 12:37
    I meant the QFP pachage.
    Tom
    Tom,
    The QFP is also in the same thread. Just scroll down a little...
