Any tube amp experts? — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2010-09-17 08:48 in General Discussion
I am building a routing system to route a guitar to any of 16 guitar amp inputs via relays. There are 3 relay boards, one to choose the amp to send the guitar to, one to choose which amp to send back out to a cab, one to choose the speaker cab to listen to. All the amps belonging to the clients of the gadget are exotic pricey tube types, ones that I do not want to blow up. If no load is on some amps, and you hit it, the amp dies. I have also sorts of opinions on how to do this, but am still not settled on it yet. Maybe someone here who knows more about tube amp fundamentals can help me out.
The guitar distribution is pretty straightforward. I don't want anything in the path except relays. The only exception is an option to drop in a transformer to convert the signal to balanced, since there is loss, I may bump this back up with an op amp with a +-5v supply attached, lower power for lower noise, since it is a small signal. A transformer box will sit on each amp for balanced to unbal conversion. A Propeller receives a serial input from a computer, and selects the correct amp(via relay) from a menu list. The timing will allow all inputs to see GND prior to switching the amp outputs. Once the amp input relay is selected, plus the amp output relay, the input(guitar) is then patched in. This way, no amp sees input until it is loaded with a speaker. What I need to resolve is, whether to keep some amount of load on all unused amp outputs. I was thinking about something higher than 4, 8 or 16, maybe around 100 - 200 ohms, using lower wattage, since at this resistance(impedance) there will be less heat. I'd like to use a 3 watter since I can get them in a convenient SMT package. With no signal, is this safe thinking to use such a low wattage resistor? I have heard that with no signal that no load is really necessary. But to be safe I am looking for more advice.
BTW for the guitar folks, this system is also a remote controlled mic stand. It moves a boom around a row/stack of amps and positions the mic anywhere on a speaker(several cameras are displayed in the app--wide angle and closeup looking down on the mic). The position is stored in a namable preset in the app for future recall. The amp and cabinet are stored in the preset as well, so on selecting the name from the preset menu, the mic goes to it's precise place, and the correct amp and cab are patched in. Future versions will have an effects loop router for all pedals, outboard gear. Below is a screen shot of the beta app, it contains a bit of diagnostic stuff on the right that will be hidden from the user later. The Propeller is used on all relay switching boards, and is connected serially(rs232 or XBee) to the computer, it controls the 4 steppers including all motion control code, accel, decel, etc. The full blown proto with vid coming soon, the extruded aluminum framing will arrive any day. The boom moves up down(6' typ), left right (4' typ), in out( 2') and rotates the mic +- 45). All navigation is via mouse or keyboard arrows. Future versions will include USB joystick control. The router actually controls sets A and B, so two amps can be used, and two cabs can be controlled at once. Shown is the Propeller 4 motor controller board, plus 4 separate drivers, 5 supplies.
Post Edited (originator) : 1/4/2007 6:34:15 AM GMT
    edited 2007-01-04 18:55
    While not anywhere near an expert, i have been around tube amps for years. You are definately playing with fire here, you can get huge voltage spikes from an unloaded output, which will fry the tubes or transformer. You can look for " dummy load " circuits, but these are not meant to be switched on the fly. Your idea could work, but the timing of the switching would have to be very accurate. An attenuator may be a safer route. Too high of an impedance can cause damage also. Since most guitar players are very sensitive about their equipment, you may want to reconsider this one. Anyway, good luck, looks great if it will work.
    kelvin
  • steve_bsteve_b Posts: 1,563
    edited 2007-01-04 22:20
    Hmmm, I've a couple of tube amps here, and there's nothing worse than hot plugging a guitar in (WHOOMP...crack).
    My amps have standby switches on the back. I don't know if you are willing to mod their amps at all, but I'd try switching to standby before switching in puts.
    The standby, I THINK, retaps the grid voltage on the tubes. The tubes will still be lit but will not have full power until you go off standby.
    If you are not able to mod their amps (I personally wouldn't want it mod'd), you'd have to look at "make-before-break" setups to switch in an RC load of some sort.
    I'd normally just go with a resistor, but there will still be a whoomp of some sort (as g'tar guys like to have their amps turned up)....the capacitor would hopefully buffer the load as things change.
    If you implemented audio transformers in your outputs of your "switching" box, then you might be able to get away with the output impedance of your box being enough of a load on the amp and then do your switching before the audio transformer. Essentially the transformer would offer some isolation....not sure how much though.
    And to note, mechanical relays are very noisy accoustically....all that arc'ing when you switch just gets amplified through amps/pedals and all...
    Interested to see your progress though.
    Steve
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
  • T ChapT Chap Posts: 4,260
    edited 2007-01-04 23:16
    I am going to buffer the inputs with an Analog Devices AD797 op amp, then buffer the outputs to each amp with the same op amp plus a parallel signal that gets balanced with an Analog Devices SSM2142 balance line driver, so that the signal can be sent in both unbalanced and balanced modes, then converted on the other end with transformers to the amps inputs. Mod'ing an amp is not doable. I am designing a relay circuit and switching system that will disallow any signal to be present when an amp in not plugged directly into a speaker into a speaker. Of course if the user fails to plug in the speaker, then he has a problem, but that problem is his to ensure with or without a router. I think with sufficient signal dead time prior to changing any amp relays, meaning there is no way to allow signal present when switching, and and inputs are insured to be at GND, there should be no problem just using a dummy resistor parked on the unused amps. As far as arcing when switching, the inputs will be muted prior to any switching, so that will help. Thanks for the tips, there is a lot to consider so thats why I am looking for ideas to avoid haedaches later.
  • Robert KubichekRobert Kubichek Posts: 343
    edited 2007-01-04 23:38
    Couldn't you use custom connectors with a pair of pins that would signal if a speaker is connected to output,
    if the signal is not there, the amp is not powered up, or switched in??????
    There are also circuits that sense an output load for amp protection ( I believe solid state )....
    edited 2007-01-04 23:47
    very good idea.
    edited 2007-01-05 19:14
    Anyone know of a circuit that could always be looking at an output to determine if a load is present, and could remain even if high wattage signals were present on the load without damaging the circuit? It would be great to always check for a speaker present, and signal an alarm if nothing is there. This is easy with no amp hitting the speaker, but I can't imagine a way with an amp in the loop.
    edited 2007-01-05 19:34
    originator said...
    ... As far as arcing when switching, the inputs will be muted prior to any switching, so that will help. Thanks for the tips, there is a lot to consider so thats why I am looking for ideas to avoid haedaches later.
    What you have to do is keep the output of your switch from creating any unwanted noises when switching. The relay will create an arc regardless of what's at your input. This arc will go through your output and into the amps where it will give a nasty whoomp.
    Even if you disabled the output of your switch, the amp would more than likely make a noise (not sure what...but essentially it lost it's load and it's input will float).
    As far as detecting what's been plugged in.....I'll assume the speakers have mono 1/4" jacks on them.
    You can use a stereo jack and look for signal between the Left and Right rings on the plug...or even from Left/Right to ground...not sure.
    On your switch end, you can have a jack that is switched...so that whenever you plug something in, it'll close the contacts and complete teh circuit (not sure if I described that right).
    Even with the plug in your output, you could still look to see if there's continuity between the Left/Right plugs so you will know you're connected.
    NOW, the trick is....you can't use a standard DMM continuity circuit since it uses DC...last thing you want to do is put DC on your speaker. We used to test our speaker coils with a 9volt battery...would pin the coil in one direction.
    You'll maybe want to use a signal below/above the range of hearing.....
    I like the project....but don't really know the best road to take!
    Steve
    edited 2007-01-05 21:49
    A battery has been the standard for testing a speaker including polarity. In this case, I may use a tiny voltage just to check continuity while the speaker is not engaged by an amp, and actually my plan is to have the processor check the output each time just prior to connecting in the amp. This way, prior to each contact, a load of some sort must be present, however this does not distinguish between a short or speaker. I was hoping for a method to be constantly checking for a load even when the amp is connected to it, in the unlikely event that a speaker blows or gets unplugged, the relay to the speaker drops and a warning is sent back to the UI that no speaker is present. I cannot find such a method to do this, so checking prior to each contact may have to suffice, which is more than any amp does anyway.
    The arcing is part of the deal, not much way around it. The other possibility I had in was mind was to have a mic mute feature that mutes the mics before all switching, then unmutes afterwards. Another thought in mind is to use a digital pot or switch, and ramp the amp input to GND prior to switching the relays, thus the amp is seeing GND before the relay changes states, This would however leave a circuit connected to all amp inputs even when in high impedance states, but that artifact may not be of consequence. I am looking at digital pots and swithes right now to decide. Ramping a voltage up and down with a DA to a coltage controlled pot is more ideal, with smoother transitions since there is no need in switching on the fly, dead time can be even a second as the mic has to move to a new place anyway, who cares if there is no instantaneous switching. Since it is Propeller controller, ramping a voltage is very easy, as well as sending one serial signal to all 16 digital pots(or vcs's) to mute them in every state change.
    Post Edited (originator) : 1/5/2007 9:58:23 PM GMT
    edited 2007-01-06 00:28
    You might be able to "switch in" I/O's with something solid state as opposed to mechanical. A JFET or something? I don't have enough experience with them.
    But you could in a Gate Source Drain type of setup, you would enable the JFET with a voltage at the Gate. now, this would be a DC signal to enable it, which means you're signal would ride on the DC and you'd have to decouple it before it goes out to the amps...no biggy..DC blocking cap is all (cap in series with output).
    What would be nice is to have the amp see the same impedance at all times at it's input so that there is no noise introduced. How do you do this?? haha not sure.
    A transformer with a resistor in parallel?? Don't know if it's that simple....
    Steve
    edited 2007-01-06 00:59
    Actually the amps will be looking at the op amp at all times, a single buffer is on the input, 16 op amps are on the output post relay. Between the input op amp and the outputs, the relays are sitting. The only issue with a JFEt may be noise introduced, although compared to the noise of a cranked amp I think it would be a non issue. I like the idea of wire straight through, no caps. The relay serves this putpose nicely, and with some type of switch to shunt the signal post relay prior to the relay, this would negate any noise introced by the relay including arcing, DC offset, etc. A 4066 even could be used as the shunt. I'll post the entire idea in a few since I think it is close.
    edited 2007-01-06 07:26
    In case you have not seen it, here is a similar product, but much simpler. They provide some info on operation.
    www.tonebone.com/tb-headbone-vt.htm
    kelvin
  • johnnyairplanejohnnyairplane Posts: 25
    edited 2007-08-23 07:33
    Hey!
    Use the 4066 Analog Switches! - I once built drummers 'cough switches' for their mics,
    absolutely silent audio switch! - had to be!
    On 'balanced' lines, open up the 2 lines (pin 2 and pin 3 on an XLR) on the mic side, while shorting 2&3 on the amp side!
    Keeps the input to the amp at 0V (obvious!) and well, this could easily be done with a uP (something we didn't have back then)
    we had 'rotary switches'.....
    Funny, I just found one of those old relics - still works!
    John
    Mr. Chap,
    Whatever happened with this project?
    DJ
