What motor is the best???
Hey guys,
I have a little project going on. At my home I have blinds in front of my closet and I want to build a BS2 in them, so that after I touch at a button, they open and the light inside wents on and so on.
I allready thought about that to move the angle of the rung, it would be the best to take a servo. But now I need a motor, that moves that whole thing up and down. So it needs a lot of power and I want to have this whole construction under 12Volt. Should I use just a normal motor and build in touch sensors, so that I can stop everything as soon it is completely down or up or should I use a stepper motor??? And can you recommend me a motor/stepper motor???
Thank you very much for an answer.
-Marc
-Marc
I would recommend a windscreen-wiper motor as they are quite powerful and have a·linkage/arm·mechanism built·in to allow for the movement (I think) you need. A wiper motor will run on anything around 6 - 12 Volts.
One problem is controlling them; i.e.: setting limits, but this can be accomplished by setting up a·micro switch rig.
- Stephen
You think this one is ok too???:
http://www.allelectronics.com/cgi-bin/item/DCM-249/search/POWERFUL_WINDSHIELD_WIPER_MOTOR_.html
And than. I have to seperate blinds. Do you think that the motor is powerful enough to push up and down both blinds together or should I purchase two of them???
Thank you for an answer.
-Marc
www.bgmicro.com has wiper motors:
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=9380
Edit: I am referring to·the motor in the link you (Marc) provided.
Post Edited (ChrisE) : 12/29/2006 6:51:56 PM GMT
Thank you guys again.
But now I have two new questions:
1. Can this motor turn forward and backward for the push up and down effect??? Is it possible to just let the pols switch, so that it turns into the other direction???
2. I need an AC to DC Adapter from 110 Volts now... It should get the Voltage down from 110 to 12 Volt and should have about 2,5 to 3 Ampere. I can't find one. Please help me.
Thank you very much
A windshield wiper motr runs in ONLY one direction, ifthat answeres your question. A gooddeal of what it does, is done by the mechanical linkage!
Search for "mechanical linkage windshield wiper".
Bruce Bates
<!--StartFragment -->
Post Edited (originator) : 12/29/2006 10:19:27 PM GMT
I am german and I searched the word pulley for hours
I thought it would be translated from german as coil and I didn't found anything
Thank you very much
Post Edited (originator) : 12/30/2006 4:24:16 AM GMT
Post Edited (randyaz) : 12/30/2006 3:24:22 AM GMT
