counter jitter
Graham Stabler
is it possible to calculate the likely jitter in the nco modes?
I'm sure I have read this but can't find it.
Graham
Graham
i.e. [noparse][[/noparse]0..12.5nS[noparse][[/noparse] at 80MHz.
- Mikael
cue the evil laugh
Graham
- Mikael
Graham
http://forums.parallax.com/showthread.php?p=583301
Jitter would be insignificant for most intents and purposes, when the PHSx period is much much greater than 12.5nS (80mhz clkfreq). For example, to generte a 999 hertz output, with FRQA=53633, the output consists of a mixture of periods of length 80080 * 12.5 nS and 80081 * 12.5nS. That tiny difference is probably not going to matter, unless the intent is in fact to make a super accurate 999 Hz oscillator. Those periods correspond to a mixture of two frequencies, 999.001 Hz and 988.989 Hz. The the mixture of the two periods follows exact numerical rules and the phase slips occur in an entirely predictable pattern.
The slip in phase is always in plus or minus a 12.5 nS subharmonic content is closely tied to the exact ratios.
Tracy Allen
www.emesystems.com
