Connecting 14 bit transducer
I have never used Parallax / BS before and would very much appreciae advice about connecting a transducer.
Is there any difficulty connectinga transducer with a 14 bit RS-232 serial output to a BS2 and controlling it with SERIN SEROUT or SHIFTIN SHIFTOUT?
The transducer I am thinking of using is on this page:
http://www.allsensors.com/products/products_industrial.htm
See 14 bit digital output at the bottom. I plan to use the barometer.
I am not clear if I should use synchronous or asynchronous control.
What I hope to achieve is a system that will accept a program via USB from a PC, [noparse][[/noparse]control if needed and] accept data from a transducer, carry out some simple instructions and close a relay if certain conditions are met.
So I'm open to any general advice.
This transducer is quite expensive, $150 or more I think. It would be equally possible to use a transducer and A/D converter. But I'm happy to spend money to save time.
Just about the only constraint is that I want to be able to use BASIC since this is the only language I know. If there is a seamless way to convert from BASIC between my keyboard and the processor that would be fine.
Any advice and suggestions very much appreciated.
Season's greetings:
-- Julian
Julian Nott www.NOTT.com
Season's greetings:
-- Julian
Rick
