power on boot
Hi
I have succesfully created a program for an sx28. It is running very fine but I'm struggeling with one thing.
If I cut the power and reboot the SX28 by applying power it is not starting the program. It is hanging at that moment. When I just puch the resetbutten I have connected it is starting. (used a reset butten with a pull up resistor).
Does anyone has suggestions on what to modify to be able to start the complete program without user transaktion at power one??
Ps I tested my chip on the professional develpingboad and thier was no problem. Now I made my own pcb and everything is working exept the power one.
All suggestions are welcome.
Stef·
Stef·
· Make sure you enable the "Brown Out Reset" on the DEVICE line.
· If you are running the SX from 5V then add BOR42 to the device line. See if that fixes it.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Thanks. I added the Bor42 in the device line and now I tested it.
Everything is working fine now.
Stef
Your welcome. Glad you got it working.
Bean.
