Right angle drives
Bill Chennault
All--
I really like the Banebot line of DC gear motors. For my application, I need a right angle drive, though. Do you have any hints of where I might look for such small, right angle drives?
Thanks and Merry Christmas!
--Bill
You are what you write.
--Bill
http://stores.ebay.co.uk/eBEAMuk_Motors_W0QQcolZ4QQdirZ1QQftidZ2QQtZkm
Hope this helps.
Do a Google search for Surplus Center to get the web site address.
Deno
Thank you very much! I really appreciate the time you spent looking for these sources. I had seen all but Surplus City (deno, I am bookmarking that one!).
The reason I am looking for a right angle drive is because I have pretty much settled on a line of motors (Banebot; assuming I can find the right angle drive that I can make work).
I've spent a lot of time looking and finally discovered that the answer MAY·be right under my nose! I am going out to get one of those new Dremel right angle attachments. I might be able to build an adapter that will allow it to work with my motors.
--Bill
You were really right about Pololu! (I refer to their motor controllers.) I especially like the specs on the Pololu 3-Amp Motor Controller with Feedback. The spec sheet at that link is well worth reading.
Do you--or anyone else--have actual experience with this particular device, or any of Pololu's motor controllers? I am particularly interested in knowing if I can use a simple Hall-effect device as the tachometer input.
Merry Christmas!
--Bill
Well, I have the 3 amp machine on the way. I'll give you a report!
--Bill
