It's simple things that get you.
After recieving much good advice from this forum I'm finally able to contribute back. I have made a bs2 oem style board. The stamp part is driving a relay. After making the pcb and soldering all components onto the board I powered it up and to my surprise the thing actually worked...well sort of. I downloaded a simple high pause low pause repeated three times. It went through the first cycle and then stopped. After a closer examination I discovered that I had forgotten one simple thing. The diode across the coil of the relay. After soldering one on I powered up and it's working perfectly!
I hope this helps someone.
Well, you get my vote! [noparse]:)[/noparse]
Although I knew you had to have a diode across the coil leads and even understand why because of this forum, I do not know what capacity device you need.
Good work!
--Bill
You are what you write.
Can you tell me what diode are u using. I also have done my own board and have few relays on it.
The board works fine but there's a little problem that cause my servo to move when I input High to the rlay.
I did'nt use any diode across the relay coil. Mightbe this is the solution.
Thanks for sharing.
Not only might that be a problem, you run the risk of killing your driver transistor (please tell me that you are using a transistor to switch the relay and are not trying to drive it from the Stamp pin). When a relay "turns off", the energy that was stored in the magnet coil leaves it as the magnetic field collapses. Without a diode, this "back-EMF" has no choice but to try to force its way through your driver...either the transistor or the...gulp...Stamp...doing damage as it does.
Truly Understand the Fundamentals and the Path will be so much easier...
