Propeller OS for Demo Board and Hydra
Mike Green
Attached is the latest version of the Propeller OS for the Demo Board and Hydra. This incorporates both the TV driver and the VGA 1024x768 Tiled driver. There are 4 precompiled sets of binary files in subfolders for TV and DemoBoard, VGA and DemoBoard, TV and Hydra, and VGA and Hydra. Changes in this version:
1) The display interface is now identical for both types of display (OS_dspText).
2) There is one centralized point to configure the type of hardware (TV vs VGA, DemoBoard vs Hydra). You still have to include the video driver
(OS_dspTextInit) and keyboard driver (OS_keyboardInit) appropriate for the type of hardware from the proper subfolder.
3) There is the beginning of Vinculum (USB host) support. Currently the initialization routine is commented out. Do NOT try to use the test
commands for this. They may hang up if the initialization code is uncommented and recompiled. It does do a few simple things on the
DemoBoard if this is done and you connect up a Vinculum as described in the comments in OS_massStorage.
Plans for the near future (1-2 weeks):
1) Set up the display initialization so both drivers are included. Only one will be used, but switching source files won't be necessary.
2) Continue working on Vinculum support so EEPROM images can be copied from and to USB flash drive files.
3) Try to combine the two keyboard and mouse drivers (DemoBoard and Hydra) so only once source is needed.
·Look's like you have everything wraped up nicely, do you want me to keep pluging away at the GUI or do you have somthing else I could help with ?
Brian
Post Edited (truckwiz) : 12/12/2006 5:16:11 AM GMT
I'm trying to provide a framework for doing things like a GUI. Not everyone who uses the PropellerOS will want to use a GUI or a mouse. Keep at it, but look at the services provided by the OS. For example, I still need to add methods to support the use of graphics within a window or other screen region. I have some ideas, but suggestions and experience are welcome.
·I'm in the middle of reading "Microcomputer displays, graphics, and Animation . Once I get done reading , I'll have see what I come up with . I can't get any of the sample programs to work on the Propeller OS . I have the demo board with the standard memory.
Thanks,Brian
You can use all the I/O routines without the command interpreter to make your own application. Take OS_mainProgram, throw out everything from after "_free" to before "PUB main", keep the "init.start" in the main method and throw out everything else that you don't want there. The "OS_initialization" starts up everything and displays the identification banner. The "OS_loader" file contains the definitions for DemoBoard vs. Hydra and TV vs. VGA. Sid (Newzed) essentially did this to make his controller.
·The sample programs ,are they stand alone objects or do you have to run them under the OS.
Brian
·Can I hook up another memory chip on the demo board & then load your sample programs on there ?
Brian
(My wife bought me a hydra for christmas & had It shipped to her moms so I have to wait for all the good stuff !)
Post Edited (truckwiz) : 12/12/2006 6:26:31 PM GMT
·I don't know what I'm doing wrong , I get the binary basic out of the demo vga file , load eeprom , load the ram with the os , copy boot to basic , reload os to eeprom , type run basic & screen goes blank.
Thanks,Brian
·Tv version works great·, I see that my leds go out when I run the VGA basic (bad loader file ?)
Brian
·Heres what I tried , deleted every os_loader & other files , created new folder , down loaded files again·& stored just vga files in folder , still does the same thing
Brian
P.s, Chips big vga tile driver does the same thing to my LCD monitor (ya i'll dig out a old monitor).
·*********** old monitor does same thing , with basic & chips tile driver **********
(the OS works on the VGA )
P.s.s , My propeller got really mad when I had 40(32, other 8 where in the next state)·buttons on screen the other day (all my leds where very dim & my monitor thought it was the sixties), I don't know if I messed up cog ?
Post Edited (truckwiz) : 12/13/2006 6:23:42 AM GMT
There also is a problem with the DataScope sample program in that it doesn't reload the OS properly in the TV version. Probably it's the same problem.
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Attached is a new binary for the DemoBoard & Hydra VGA and source for the VGA driver that corrects the bug you saw. The VGA driver was "registering" its cogs improperly and the loader turned off the VGA driver. There's still a problem with reloading the OS after running a program.
Sid,
There's no great advantage in messing up something that works fine for you. As features are added, decide if they're really useful for you first.
Lunch hour not long enough , I will play with it tonight .
Brian
·Works great , reminds of the first time I sat in front of a apple. ( I don't know if thats good or not)
Brian
Can you save in basic , what kind of syntax are you using on INPUT ??
Brian
The sample programs (SimpleBasic and DataScope) were written by others and posted to this forum some time ago. I modified them minimally to use the OS's keyboard and display drivers and to be able to exit back to the OS. That's all. They were included to demonstrate what's necessary to do that.
Post Edited (Mike Green) : 12/14/2006 12:13:30 AM GMT
Brian
Post Edited (truckwiz) : 12/14/2006 2:57:45 AM GMT
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
No. I wrote that to help debug your program and haven't had any reason to use it further. One of Martin Hebel's students is trying to do something similar with shiftin/shiftout (this thread: http://forums.parallax.com/showthread.php?p=620870). It's a very useful concept, particularly with the Propeller where there are usually extra processors available
I had a dream last night, A on chip assembler to go with your OS , I'll try to hammer out something to start with tonight.
Brian
I downloaded your new OS and Hydra version but could not get it to display.· I was running " simpleDemo.spin " with all the required objects, and in the CON block of OS_loader I changed:
·dspPinGroup = (TV & tvPinGroup) | (VGA & 16)·
to read:
·dspPinGroup = (TV & tvPinGroup) | (VGA & 8)
Do I need to do something else?
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
The OS_windowEditor object is intended to be the beginning of a simple text editor for just such a project. I wanted to get some kind of mass storage support into the OS before I changed my focus to this. It mostly needs support for multiple pages and scrolling. It would be pretty easy to load and store 32K text images which would be enough for most assembly programming. The assembler could have provisions for an "include" statement so larger programs could be made up of several pieces < 32K of text.
Make sure the other constants earlier in OS_loader are set properly (TV = false, Parallax = true). The Demo Board and Hydra use different crystals and PLL settings and the Parallax constant adjusts for that.
Chip's new VGA driver uses a 60Hz refresh rate which should work with pretty much any VGA monitor at 1024 x 768.
Brian
I got OS_mainprogram running OK.· Tried to change the colors but got nowhere.· If I enter Setcolor or Setcolors the screen says "Unkown command".· Can you show me one time how to change scrren colors, say yellow font on blue background?
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
