Fingerprint scanner, data storage,
I need to find a solution for reading a finger print, storing up to some amount of prints for multiple user, and finally, being able to send the data to and from other devices. The processor already on the conroller board is the Propeller with extra i/o available.
There are two scenerios, one involves a PC as the print acquisition and storage, where each entryway(s) using the scanner accesses the main PC terminal to confirm/decline the attempted entry via print input. In this case, all scans are first loaded in the PC, the remote scan terminals are siply communicating to the PC. The PC can delete or susspend the particular fingerprint/user with a proprietary application for managing access.
The second scenerio preferably does not use a PC, but rather the Propeller for acquisition and storage(SD?) of X number or prints(at least 5 users). This case does not share it's data with other entryways or is it networked, pnly one entry system to control, and use the Propeller, scanner, and data storage medium all as one self contained unit. This will of course require some buttons to control the data input and naming scheme, most likely using an LCD.
Googling has turned up no good answers on how to get started reading a print, if anyone has any quick thoughts on the subject please share them! Thanks
It's Only A Stupid Question If You Have Not Googled It First!!
I·just recieved a sample fingerprint scanner that will hold i believe 80 users.
Can you give an web page to get a sample
Thanks For any help that you can give in this matter
Sam······
i was incorrect. it will hold 188 profiles
Qoute from correspondence.
- Remeber, the FPC-AM can store 188 templates, coming version built on
the new FPC2020 Processor will be able to handle about 500. Templates
can be stored in a central database and be distributed (downloaded) to
the modules/units to serve the right population group but we are not
providing a performing solution for real-time use towards a central
template database storage only.
http://www.cdiweb.com/inventory
It is serially communicated to.· A form of SPI.· Very cool, small little device.
It can also pull from a database.· I have well over 188 users so what i have planned is to have a keypad that the user will use a 4 digit number.· I cann give this number to 188 individuals.· It will upload the database for these and then verify the fingerprint.
Post Edited (altitudeap) : 12/8/2006 4:33:13 AM GMT
Post Edited (originator) : 12/8/2006 7:52:44 AM GMT
