music code
I am working through the WAM book and loving it. I am working on the sound chapter. Is there a place I can find code for songs that I can plug into a code? I am using the BS2.
Thanks for the help
Josh Richard
Technology Education Teacher
Spring Grove Area High School
Richardj@sgasd.org
Thanks for the help
Josh Richard
Richardj@sgasd.org
"Gettin' Midi With it"
"Mo Midi"
"Even Mo' Midi" > for the SX
Rodney
I have a few scores that more or less follow the WAM music engine, but I changed the engine itself a bit so that the data is easier to sight "read" and to use fewer variables. I can post my version and my scores if you want.
Post Edited (Zoot) : 12/7/2006 5:36:25 PM GMT
Josh Richard
Richardj@sgasd.org
I edited the file to take out all the stuff related to my own particular 'bot, so hopefully I didn't make any errors -- it tokenizes, but I didn't run it.
The Mozart was transcribed by my partner so don't blame me
Also, my own 'bot has an speaker with a frequency range of about 550hz-5800hz -- if you are using a piezo you may want to check the octaves in my scores -- the lower octaves are probably out of range for a piezo.
