quadrature encoders — Parallax Forums
quadrature encoders
JTCJTC Posts: 60
edited 2014-02-04 08:10 in Propeller 1
To anyone. I am new to the propeller and am trying to decide if it is the chip I want to use.
Has anyone used a quadrature encoder to read the feedback from a servo motor ?
The encoder is a 250cpr and will be used as a Z axis CNC plasma table.
What kind of speeds will the propeller chip read ?
Thank You
Jim
    edited 2006-11-22 18:19
    Jim,
    Jeff Martin has worked out a very nice object that will support up to 16 rotary encoders.· I have attached the file, and derived·some·of the·formulas
    from the document that allows you to calculate the number of 'clock cycles' and maximum RPM the encoder·can operate.
    Total Cycles = 144 + 50*(Number of Encoders-1)
    RPM of Highest Resolution Encoder = XINFreq * PLLMultiplier / Total Cycles / 2 / MaxEncPulsesPerRevolution * 60
    Example 1: Using a 4 MHz crystal, 8x internal multiplier, 16 encoders where the highest resolution encoders is·250 pulses per revolution:
    ·········· Max RPM = 4,000,000 * 8 / 894 / 2 /·250 * 60 = 4,295 RPM
    Example 2: Using same example above, but with only 2 encoders of·250 pulses per revolution:
    ·········· Max RPM = 4,000,000 * 8 / 194 / 2 /·250 * 60 = 19,793 RPM
    Example 3: Same as Example 1 above except a 5MHz crystal is used with a PLL value of x16·:
    ·········· Max RPM = 5,000,000 *·16 / 894 / 2 /·250 * 60 = 10,738 RPM
    Example 4: Same as Example·2 above except a 5MHz crystal is used with a PLL value of x16 :
    ·········· Max RPM = 5,000,000 *·16 / 194 / 2 /·250 * 60 =·49,484 RPM
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 11/22/2006 6:25:22 PM GMT
  • JTCJTC Posts: 60
    edited 2006-11-22 20:29
    Wow ! you guys are great.
    I guess I need to invest in the propeller development kit .
  • JTCJTC Posts: 60
    edited 2006-12-02 00:21
    Well my propeller came today so I can get to work learning it.
    Thanks for your help.
    Jim
  • Richard S.Richard S. Posts: 70
    edited 2006-12-19 04:00
    I worked through the math for max. rpm's and do not come up with the same results.· Am I missing something?· Brackets to delineate sequence of steps would be helpful.·
    If a separate cog counts each axis, i.e. X, Y, Z...why the increasing overhead for software as cogs (encoders) are added?· Can't each cog dump the results into shared memory independent of the others?
    I am new to Propeller.· Board is on order.· Fascinating chip!·
    Richard in Michigan.
    edited 2006-12-19 04:50
    I figured out the math...just sequentially do the divides and multiplies.
    Richard in Michigan
  • epinehepineh Posts: 14
    edited 2007-01-01 11:02
    Keep us informed how you go Jim, myself I am interested in using a rotary encoder on a stepper motor, using it to check for lost steps, and of course correct on the fly, similiar to servo's, but at much less cost both in motor's and drivers.
    I have built my first 3-axis timber router and having a ball with it, a friend used a similiar machine to rout a PCB for a Prop development board, I have just finished getting it setup, ran the obligatory flashing LED program's today.
    The intention is to use a Prop for the brains of my next machine, with the features I mentioned, and maybe a nice LCD display to Woo onlookers...
    Cheers.
    Russell.
  • JTCJTC Posts: 60
    edited 2007-03-27 03:19
    · I got mine about a month or so ago and have been trying to get my old brain around the programming. A lot different than what did before. I think it is the fact that I have 8 processors and I am trying to figure out how to make use of them.
    The stepper motor idea is a good one. I had thought something similar but didn't feel I am up to the programming that needs to be done. It is coming... just need to spend a bit more time expermiting with it.
    I do have my first product about 90% done and·my customer is pleased with the results so far.
    I·use a 5 inch color video monitor instead of the LCD. I bought the LCD but it is so easy to use video I used it. You can get a game video flat screen at Marlin P. Jones online for about $50.00 makes programming more enjoyable for sure.
    Jim
  • scottascotta Posts: 168
    edited 2007-03-27 04:22
    JTC,
    I have used a variation of the QuadratureEncoder routine up to it's limit.
    A 4096 ppr encoder will clobber it, but 250 ppr on a single cog is not an issue.
    I have a single Cog reading Position, velocity and acceleration on 4 axises
    and with 4096 ppr encoders, the cog is asking for more to do.
    This chip is fantastic:
    http://forums.parallax.com/forums/default.aspx?f=25&m=181024
    Scott
    edited 2007-03-27 05:18
    I am curious to hear from you guys just what kind of·performance you could actually use in a quadrature encoder object.
    Is the sky the limit, or is 30k rpm at 4096 counts per revolution (2.048 MHz) beyond necessary? Just how much is needed to put things well in the black for an advanced project of yours? And for how many concurrent channels, ideally?
    Chip Gracey
  • OzStampOzStamp Posts: 377
    edited 2007-03-27 06:21
    Hi Chip
    Hope you and fam are all well.
    A typical small/medium size PLC has 2 to 4 high speed encoder inputs.
    Normally the first 4 or 8 inputs are dedicated to high speed pulse counting in either single
    or quadrature input mode..( A + B phase + optional Zero marker for cntr reset )
    Typical input frqs are in the 100KHZ for most small/medium type plcs's .
    Special input cards that cost megabucks will count around the 1-2MHZ not aware of all
    the ins and out of all the brands .. sure somebody can add to my details.
    Once you start looking at Motion Controllers ..ie feedback for positioning loops for feedback..
    pule rates are a little higher .. some controllers can capture up to 10MHZ easily ( dedicated hardwarre)
    with associated loop update times of 50 to 100 micro_secs typcially etc etc... (PID loops for positioning)
    Cheers
    Ronald Nollet Australia
    edited 2007-03-27 12:46
    A table top cnc machine with encoders on the motor won't need much more
    than the current chip has.
    An external decoder IC might be necessary if we start using rail mounted
    Heidenhain encoders.
    Scott
  • SkogsgurraSkogsgurra Posts: 231
    edited 2007-03-27 20:50
    I am possibly missing something - or someone else is - but there are two distinct type of encoders; absolute (mostly Grey) encoders and incremental (the channel A/channel B types). The example given in Rotary Encoder.spin is for an absolute Grey encoder and can not be used for the more common (and usually cheaper) incremental encoders. For the latter, I have used an encoding technique that is less known, but very fast. I have tested it in Spin and it can count close to 10 000 edges/second in high-level language.
    I haven't got to the ASM part of the Prop yet, but assuming that assembler is around 100 times faster, it should be able to do 1 MHz edge rate. Perhaps someone could put together an ASM piece of code to test it? Or wait a week until I have done it myself.
    See my post "Code Decodes Encoder" for a description and a piece of Spin code.
  • T ChapT Chap Posts: 4,260
    edited 2007-03-27 20:59
    The rotary object does work for A/B encoders, I use it everyday with multiple A/B types. I think there is some misunderstanding with the document, and there was some conversation about this a long time ago, I'm not sure why it is defined as is.
    Post Edited (TChapman) : 3/27/2007 9:03:43 PM GMT
    edited 2007-03-28 12:37
    OK, I have had a more thorough look at the Rotary Encoder.spin.
    It is written for the incremental encoder type. And can handle lots of them.
    The term Grey Coded is being used in the functional description and that is what misled me. Gray Code is usually reserved for absolute encoders having the typical "straddling" pattern and usually something like eight - twenty tracks that are read in parallel.
    The term Grey Coded is correct, though, (what else did you expect frpm Prop guys?) in the sense that only one bit position changes at a time.
    The technique used is xoring to detect edges and then checking bits to see if it is a forward or backwards movement. The usual and/or chain is avoided - which is very good.
    My version does it a little different. I shift "old pattern" left twice and add "new pattern" to get a number ranging from $0 to $F. I then use the number to look up the increment in a table containing 0 (no movement), +1 (fwd) and -1 (bwd) to add to the ctr. It will be very interesting to compare speeds between the two versions. But, as I said, I have to get warm using assembler before I can do that. Anyone else?
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2007-03-28 13:25
    I had the same confusion with the term gray code, so much so that I misread the description of "up to 16 2-bit encoders" as "16-bit encoders" and ignored it! Doh!
    Actually because I needed speed it made more sense for the encoder code to be inline with my assembly, in those cases you can probably do better than the object anyway because you don't have to deal with hub ram.
    Are you wondering about encoder read mode for the counters in Prop MkII Chip?
    Graham
    edited 2007-03-28 17:27
    Skogsgurra said...
    That's the most efficient technique I've seen. You could use a single long to hold all 16 of the 2-bit lookup values. Use the old+new 4 bits * 2 as a SHL·argument and then do a SAR #30. Then, you will have a 32-bit (-1, 0, or 1) value that you can add into you accumulator. It would take the least amount of code, anyway.
    Chip Gracey
    edited 2007-03-28 17:49
    I think you got it Chip!
    I am trying to get a working code in asm, but I need some experience with the Prop asm before i can do it effieciently. I guess that you could do it in a few minutes - please show us.
    Regarding what is needed in terms of resolution and speed, there's a lot of exageration. I do a lot of paper machine drive work. The accuracy needed there is nowadays around 0.005 % in the speed loop. That can be achieved with a 500 PPR encoder (although the standard seems to be 1024 PPR nowadays) and some smart coding using reciprocal measurement over a limited time. Usually between 1 and 5 milliseconds. Motors seldom run faster than 2000 RPM in such applications.
    On the other hand, a machine-tool servo may need a 4096 PPR encoder, or better. Motors reach up to 10 kRPM, so I think that is where you need to be. If using a linear encoder with 1 microns resolution and a maximum speed around 1 m/s you arrive at 4 000 000 edges/second. That would be a possibility, I think, with the 4xOLD+New technique. Boy, do I want to test it in the Prop!
  • Jeff MartinJeff Martin Posts: 762
    edited 2007-03-28 23:01
    I agree, that's a great way to do it:·short code and very fast!
    --Jeff Martin
    · Sr. Software Engineer
    · Parallax, Inc.
    edited 2007-03-29 00:17
    I have been working with the rotary_encoder.spin. I have a working 4 encoder model using vga_text.spin and keyboard.spin. It will accept simple keyboard commands and display encoder values. I have just started work on developing a menu for other functions. What I need to develop is a way to display a numeric string from the keyboard, justify it in reference to a decimal point, pad zeros and then strip out the decimal point and convert the numeric integer to binary. My encoder readout displays green positive numbers and red negative numbers. If interested, I can post my work in progress.
    Richard in Michigan
    edited 2007-05-25 22:09
    Well Skogs,
    I actually needed some neat and fast encoder reading action so here it is attached using your idea and Chip's single long lookup table. Its just some raw code to be included into a proper object and it just does the one encoder however it works fine.
    Graham
    here's the main part of the code, short and sweet huh!
    entry                   mov   combined, #0
    :loop                   mov   look, lookyup        ' load look up table
                            mov   state, ina           ' Read inputs
                            and   state, pinmask       ' Mask
                            shl   combined,#2          ' Shift old bits left
                            or    combined,state       ' combine to provide 4 bit word
                            and   combined,#15         ' mask off really old bits
                            mov   shift,combined       ' Make ready to use as index
                            shl   shift,#1             ' Shift to multiply by two
                            shl   look,shift           ' Use to shift look up table bits to bits 30,31
                            sar   look,#30             ' Shift to bits 0 and 1 keeping the sign
                            adds  count,look           ' Add the result to the count
                            jmp   #:loop
    pinmask                 long    %0011
    count                   long    0
    combined                long    0
    '                                 0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15
    lookyup                 long    %00_01_11_00_11_00_00_01_01_00_00_11_00_11_01_00
    state                   res     1
    look                    res     1
    shift                   res     1
  • JTCJTC Posts: 60
    edited 2007-05-25 22:22
    Good job Graham.
    Jim
    edited 2007-05-25 22:33
    Thanks Jim, it was harder than it should have been, I shifted twice to multiply by two at first (sounds feasible, doh) and later just had a one where I needed a #1, very confusing and it kids your mind into thinking its OK.
    I've got this code reading an encoder then dividing down the pulse stream to send to a stepper motor, all so I can convert a HP printer into a Zcorp 3D printer without doing an entire printer's firmware. The propeller monitors the encoder and when it sees the high frequency of a paper feed it goes into sync mode, its lind of spooky.
    Graham
  • rjo_rjo_ Posts: 1,825
    edited 2007-05-26 16:48
    Graham...
    You could also use it to make 3D lenticular prints... I have a whole bunch of film!!!
    Propeller holograms anyone?
    Talk to Graham[noparse]:)[/noparse]
    Rich
    edited 2007-05-26 17:28
    Not unless they can be made from cornstarch.
    edited 2007-06-05 08:05
    Thanks Graham!
    It took me some time to understand what you did to my algorithm. It was the sign part that I had to think about. Neat!
    Now, how fast can it go? Anyone tested already? I have been too busy to do any real work with the Prop for a long, long time. But I will surely set up a test as soon as I get the time for it.
    I have one little problem, still: The lookyup long seems to be backwards. I always have bit # 0 to the right (LSB). Does it really work when you reverse it?
    edited 2007-06-05 08:27
    Sorry, I didn't read the comments. Shouldv'e done that. I see now, why it works with reversed data; the lookyup is symmetric, it doesn't matter from which direction you read it!
    edited 2007-06-05 10:30
    12 commands in the loop (including the jmp) so I assume that is (1/80000000)*4*12 seconds per loop, 1.6Mhz 50krpm for a 500cpr encoder.
    BUT at the moment it does not write the data to main memory or anything so that would add a bit more delay.
    Graham
  • JTCJTC Posts: 60
    edited 2007-06-05 13:48
    Graham,
    ·· Have you done a speed test on you code.
    Just wondering ?
    Jim
    edited 2007-06-05 13:50
    No but I can soon add a pin toggle and hook up the scope.
    Graham
    edited 2007-06-05 14:31
    That's very good, Graham. I seldom need more than 50 kHz in a typical high-precision drive. (1024 PPR and 3000 RPM). Another idea: Out of the 16 possible combinations, four are FWD and four are BWD. The remaining eight combinations represent illegal states that never shall occur. It would then be an easy matter to check for them (zeroes in the lookyup) and either shut down or issue a warning. Either directly (I guess that that wouldn't be very popular) or after a number of illegal combinations has occured - possibly within a prescribed time.
