RCA chip needed for ferrari
An 8 pin DIP with markings on top RCA 323 and 92967, stamped on bottom 6PSTV and P3115 from a Ferrari
Unable to locate what this chip is, but the controller board is over 400 bucks so it would be nice to find a replacement chip.
This is the only chip on the board. It seems to be a driver that drives a magnetic motor to drive the speedometer
I can find out more info but I thought some old RCA guy might have a bunch of these chips in a drawer somplace.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 12/1/2006 5:11:46 PM GMT
Here is a web page that you find what you are looking for
Part cross over to a EGC 323 this is what they had on ther web page
http://client.icsource.com/ICSourceWDL/WebRental.aspx?user=chipdir&base=RCA+323+
You can also call these people at
Headquarters
1-Source Electronic Components
591-B Bicycle Path
Port Jefferson Station, NY 11776-3421
Phone 1-800-966-8826 (Toll-Free)
1-631-642-2479 (Direct)
They show that they have the RCA323 in stock
I hope this helps you with your tring to fix
Sam
Post Edited (sam_sam_sam) : 12/1/2006 10:46:20 PM GMT
lets see what this does... KA BOOM (note to self do not cross red and black)
This seems to be just transistors in an IC package.
If that is the case, replacement with something more generic should be quite affordable.
What ever you do, don't say Ferrari [noparse][[/noparse]unless you want to pay more].
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Too many websites listing 'PDF for $$$'.
Since this is Siemens, I suspect you can go directly to their site and get free info.
If you look at the cross-references, there are 2nxxxx listings.
This is why I think it is merely transistors.
So, try Phillips as well.
