Video at 20MHz? — Parallax Forums
Video at 20MHz?
rokickirokicki Posts: 1,000
edited 2006-11-27 20:29 in Propeller 1
The documentation in TV.spin seems to indicate it should work at 20MHz as well as 40MHz
and 80MHz (for NTSC). Yet, it doesn't seem to work for me; at 20 and 40MHz, the screen
shows garbage; at 10MHz and below, the video is disabled.
Is there a trick to this, or is this expected behavior?
Thanks!
(I want to run at 20MHz so I can debug some things with my old, slow oscilloscope.)
-tom
  • AndreLAndreL Posts: 1,004
    edited 2006-11-22 08:02
    40Mhz should work fine, 20 is pushing it. I can't get it to work right off the bat, but could probably make it work if I had to. But, 40 should work no problem.
    Andre'
  • rokickirokicki Posts: 1,000
    Interesting. The documentation *seems* to infer it should just work as low as 20MHz. But clearly it
    doesn't. Anyone else tried?
