Tom, · ·· Multiplexing the display directly from the H/W board is probably going to be the lowest power option…It will use more I/O pins and be tricky to code if you’ve never done that before, but it could be done, and if you’re only using a temperature chip, such as the DS1620 you should be set.· I hope this helps.· Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
Tom, · ·· Yes, that is correct…A Parallel LCD would have significantly less current draw.· When you said 2-digit display I assumed, perhaps incorrectly, that you wanted an LED display.
Chris Savage
Is most of the 20ma that something like Parallax 27976 Serial LCD uses consumed by the serial driver?
I know low power consumption can be achieved in a display, since we see clocks with always-on displays running on a battery or two.
Any suggestions on a multiplex LCD and sample docs and code?
Chris Savage
