Powering the BS2
Hey I'm pretty new to electronics, and·I have a real simple question, and I'm sure·I will get a lot of responses.· I have a bs2 on a board of education board, and I know the microcontroller can be powered with up to 12VDC, my question is if I connect a 12V battery to the Board, will it fry the microcontroller, if so why?? And if not why not??
You can find a table with information regarding power supplies based on the combination of microcontroller and carrier board you have:
http://www.parallax.com/html_pages/products/componentshop/power.asp
All of our boards are meant to be connected to VDC supplies, so your battery is just fine. The label in the USB PCB (Printed Circuit Board) is trying to cover all the possible module combinations that you could plug in it and that’s why it states 6-9 Volts. As you can see in the table in the link above, you can use 12 Volts with the BS2 microcontroller in the BOE.
Aristides Alvarez
Education and Technical Support Manager
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
-Martin
Martin Hebel
I'm going to subject my BS2 to a high current 12VDC source with 20A fluctuating·parallel inductive loads.·I'm not anticipating any problems, but if I have any you'll read about them on this forum.
