basic stamp1
I have unsuccsesfully tried to make a infrared signal like the ones used for infrared detection of 38,5 in a analog sircuit. And can not do.
It works perfect on a BS2, My question is, can "FREQOUT #, 1, 38500" be used on BS1? continuesly ? and what is the lifespan on the BS1 and BS2 in years.Getting BS1 seems to be the easyest solution instead of that analog troubble..
Lookup FREQOUT and see if there is an ICON for the BS#1.
Okay, I did it already and it refers you to SOUND. The FREQOUT command isn't available.
Ummmm. Looking at SOUND, you seem to be limited to 10,550 Hz tops. So unless you can generate a harmonic resonance, my guess is nope.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
·· George is correct…FREQOUT is not available on the BS1.· You would need a BS2 to do what you are asking.· Take care.
Chris Savage
Parallax Tech Support
will try to do analog again..
