What ZIF Socket for the QFN ?
Hey, can someone please tell me what ZIF socket I need for the QFN chip ?
Can I get it from Digi-key. I need to order parts.
-Areal
Could someone please tell me what kind of part this is ?
It’s the single female row·13 position connector (dark colored) directly to the right
Of the small breadboard on the demo board. I can’t find this part anywhere.
I know it's just a simple female connector, but it's 13 positions long.
http://www.parallax.com/images/prod_jpg/32100.jpg
What’s the general name of it ? and where can I get a close look alike ?
It’s for my propeller·hot-rod project
Post Edited (Areal Person) : 11/21/2006 9:51:06 PM GMT
Thanks, I guess I overlooked it.
-Areal
-Areal
Why are you working with the QFN anyway, why not the QFP? I would use QFN in a tight design but otherwise there is no problem using QFP.
*Peter*
Getting appropriate QFN and LQFP sockets for our Propeller testers was a very long (and expensive) process. We tried several different manufacturers' sockets before we found·ANY that even worked with our packages.·You would think this would have been a simple matter, but it was very complicated because of the many subtleties which exist between apparently matching chips and sockets. In two cases, we actually built test boards before being able to tell that there was some show-stopping problem with the socket. In the end, the only QFN sockets that we found useable for the P8X32A-M44·were these from Plastronics:
44QN65F19090
44LQ65F19090
I began to post the drawings for these, but then realized that they were marked 'proprietary' by Plastronics. So, you'll probably need to contact them to have them send you the drawings. I tried Googling the .pdf names, but nothing came up. Unless you really need to insert and remove parts, I would just solder the part to a PCB and forget about it. These sockets are expensive and tightly pitched in metric units. Like I said, unless you're really up to it, I wouldn't bother with a socket. We need them to test production·chips, but shy of that,·I would never·use one.
Chip Gracey
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
