Serial LCD Display(Clock Program) and QTI sensor...
ok so ive been trying to work on a program that uses my LCD Serial display as a clock(i have the clock program for it working) and using·a single QTI senspr to make the clock stop. Here is what i need to happen. When i start this [noparse][[/noparse]program the clock needs to start and when the QTI sensor reads an object in front of it i need the clock to stop..My clock has seconds, minutes, and hours. I am using the board of education and a BS2 chip..Pretty much basic parallax stuff but i cant figure out the programming..if anyone could help me it would be appreciated..thanks
If you don't have some sort of external clock chip (you don't mention one), how are you planning on obtaining the correct time?
Bruce Bates
<!--StartFragment -->
Would that work for you?
