Is my serial LCD a dud?
Hi guys,
Recently I bought some stuff from Parallax, including a 27977 backlit serial 2 x 16 LCD. To use initially on my Professional Development Board and later in my current project.
Anyhow, I finally got around to hooking it up this afternoon. But I just can't get it to work. To test it I hooked up +5v from VDD bus on the prof dev board and GND from the VSS. I set the DIP switches to OFF,OFF for TEST mode, powered it up and the backlight came on. I then tried adjusting the contrast but no text displays on the LCD.
I even tried a simple test program, but that didn't work either.
Can I try anything else? Or is my LCD dead?
Steve
Steve
·· Please contact Tech Support tomorrow (Monday) when you have everything setup so we can help you troubleshoot your setup.· Take care.
Chris Savage
Parallax Tech Support
It's been nearly 3 days now. What should I do?
Steve
·· An e-mail reply for information was sent out with no reply.· I just replied again.· We need the requested information in the e-mail to proceed.· Thank you.
Chris Savage
Dave
Dave Andreae
Parallax Tech Support·
