Music driven bs2p40
whats up guys? So I'm trying to interface an LM3916 to a BS2P40 to make lights dance to the beat of music but it dosen't seem to be working. Any ideas? I'm connecting LED 10 from the LM3916 to one of the I/O's on the bs2p40. Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Boombox
-Boombox
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
I'm looking at your diagram and am unsure which "9" you are talking about. There's pin 9 of the stamp (which is P4) and then there's P9 (which is pin 14)....but then you go your own header....
I'm using FIREFOX on a mac and can't seem to download/open your pdf....bizarre!
Steve
Oh, could you be having the BS2p40 playing music with SOUNDOUT commands? Ah, if that's true
you'll need to low-pass filter the output of the BS2 since its ""music" is produced with PWM and not a
nice "analog" signal which the 3916 wants to have on its input. In this case, probably best to add a
low-pass filter to the output pin of your BS2 before feeding that output to your 3916.
Keep in mind that some level adjustment may be needed, say with a resistor divider (if the output is
too high of a voltage) or an op amp (if the output is too low). The main thing here is to read that
datasheet for the 3916 and see what voltage levels it is expecting!
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Post Edited (Fe2o3Fish) : 11/10/2006 1:43:39 AM GMT
Any ideas?
Thanks!
Boombox
Thanks everyone!
Boombox
-Rusty-
