Music driven bs2p40
whats up guys? So I'm trying to interface an LM3916 to a BS2P40 to make lights dance to the beat of music but it dosen't seem to be working. Any ideas? I'm connecting LED 10 from the LM3916 to one of the I/O's on the bs2p40. Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Boombox
-Boombox
pdf
973K
Steve
I'm looking at your diagram and am unsure which "9" you are talking about. There's pin 9 of the stamp (which is P4) and then there's P9 (which is pin 14)....but then you go your own header....
I'm using FIREFOX on a mac and can't seem to download/open your pdf....bizarre!
Steve
Oh, could you be having the BS2p40 playing music with SOUNDOUT commands? Ah, if that's true
you'll need to low-pass filter the output of the BS2 since its ""music" is produced with PWM and not a
nice "analog" signal which the 3916 wants to have on its input. In this case, probably best to add a
low-pass filter to the output pin of your BS2 before feeding that output to your 3916.
Keep in mind that some level adjustment may be needed, say with a resistor divider (if the output is
too high of a voltage) or an op amp (if the output is too low). The main thing here is to read that
datasheet for the 3916 and see what voltage levels it is expecting!
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Post Edited (Fe2o3Fish) : 11/10/2006 1:43:39 AM GMT
Any ideas?
Thanks!
Boombox
Thanks everyone!
Boombox
-Rusty-
