Parallax Servo Controller - relax?
Is there any easy way to order the PSC to stop refreshing the servos, allowing them to 'relax'?
I know the Pololu supports this, but I'd rather use the Parallax as it's cheaper and uses the better supported FTDI chip in the USB model.
~Lake
~Lake
This very subject came up last month, and there is no simple way (via command, etc) to have the refresh stop. There were some add-on suggestions (additional circuity) that might be used, but that really complicates (wiring-wise) a rather simple servo controller.
Sorry for now, but if enough feedback is seen by Parallax, it may cause them to consider a firmware upgrade. Parallax has always been known as a considerate company that responds to its user base, and its customers.
Bruce Bates
<!--StartFragment -->
Thanks for the quick response. I'll probably just attach (yet another) Parallax USB to RS232 adapter to a serial Pololu device rather than bother trying out a new USB/Serial chip.
Post Edited (LakeSolon) : 11/5/2006 2:06:21 PM GMT
