I don't get it, the book says 50MHZ — Parallax Forums
metron9metron9 Posts: 1,100
edited 2006-11-04 03:08 in General Discussion
The book says on page 28 use the settings below, the sxkey will generate 50mhz but I cant get it to go more than 4mhz
Heck I thought it was going 50mhz but a loop shows the scope output Tried with resonator The ones I got say 500.L no speed change with those but if I use one of the ones that say 400?450 and another one that says 600?015 they make it go about 500KHZ so I am lost.
CS1_8255 PIN RB.4 OUTPUT
XXX:
high cs1_8255
low cs1_8255
goto xxx
' Device Settings
DEVICE SX28L, TURBO, STACKX, OSCHS2
IRC_CAL IRC_FAST
FREQ 50_000_000
ID "SXB 1.50"
Indeed the OSC2 has a 50mhz clock on it it is taking 11 clock cycles to execute what should be 2 clock cycles
Hmmm...
Think outside the BOX!
Post Edited (metron9) : 11/3/2006 8:03:01 AM GMT
  • BeanBean Posts: 8,129
    edited 2006-11-03 11:37
    metron,
    HIGH and LOW also setup the pin direction. That's why it takes more cycles.
    Use:
    OUTPUT pin
    DO
    pin = 1
    pin = 0
    LOOP
    However, you are going to run into read/modify/write problems at high speeds.
    Bean.
    Cheap used 4-digit LED display with driver IC·www.hc4led.com
    Low power SD Data Logger www.sddatalogger.com
    SX-Video Display Modules www.sxvm.com
    "People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2006-11-03 12:20
    The SX Key DEVICE setting shows INTERNAL 4MHz down to INTERNAL 32 KHz. Externally you can connect up to 75 MHz but not used rarely over 50 MHz for stability reasons I beleive. However, as a general rule, you should run your programs as slow as possible depending on the application requirements. I usually work with Internal 4 MHz because I don't have to use a resonator. However, if I have something that has alot of processing going on or something with serial communications, the internal 4 Mhz clock won't cut it so I have read on the forum here. If you are using DEBUG mode, you never want to have a resonator or crystal used and "will" damage the SX-Key. It's easier just to use the Internal 4 MHz setting.
    BTW: I have to do some stuff with my wife this morning so I hope to get back to the 8255 circuit later this morning.
  • metron9metron9 Posts: 1,100
    edited 2006-11-03 14:46
    Hey I guess that's why time critical stuff I like Assembler.
    This was just a quick check to see what speed it was operating at as T&E had asked if i used a resonator on the 50mhz test I did on his project. I originally thought I had read the sxkey generates the 50mhz and it does.
    So T&E, the sxkey itself generates 50mhz when told to do so by the device settings. The internal 4mhz to 32khz is the internal oscillator on the chip. Generally you do not want to use the internal oscillator for serial communications because it is not precise enough on the ATMEL parts I have worked with. I don't know the stability of the sx internal oscillator. In your project you ace clocking the data out so it doesn't matter.
    Picture, you can see the first red line on off is 200ns and the second one is actually 2 clock cycles or 40ns starting on the rising edge of the clock signal. I only have a 100mhz scope so measuring 50mhz is the limit due to some guys law I forgot his name, Bean knows.
    Curious why the same machine code instruction is genersted by SX/B in both lines 195 and 201, as well as 203, and 209 for the LOW command, anyone know?
     =0000004C       XXX:                             ;XXX:
       194
       195  004C  0586        SETB CS1_8255                  ;high cs1_8255
       196  004D  0CFB        MOV FSR,#__TRISB
            004E  0024
       197  004F  0480        CLRB IND.4
       198  0050  005F        MODE $0F
       199  0051  0200        MOV !RB,IND
            0052  0006
       200  0053  0018        BANK $00
       201  0054  0586        SETB CS1_8255
       202
       203  0055  0486        CLRB CS1_8255                  ;low cs1_8255
       204  0056  0CFB        MOV FSR,#__TRISB
            0057  0024
       205  0058  0480        CLRB IND.4
       206  0059  005F        MODE $0F
       207  005A  0200        MOV !RB,IND
            005B  0006
       208  005C  0018        BANK $00
       209  005D  0486        CLRB CS1_8255
       210
       211  005E  0586        SETB rb.4                      ;rb.4=1
       212
       213  005F  0486        CLRB rb.4                      ;rb.4=0
       214
       215  0060  0010        JMP @xxx                       ;goto xxx
            0061  0A4C
       216
    823 x 447 - 16K
  • PJMontyPJMonty Posts: 983
    edited 2006-11-03 16:43
    Metron9,
    The guy's name you're thinking of is Nyquist, and he's famous for the Nyquist theorem. However, the Nyquist theorem has to do with sampling systems (such as analog to digital converters) and has nothing to do with plain old analog systems. Thus, if you have a scope that goes to 100 MHz, then you can read a signal up to 100 MHz.
    Here's some info if you want to read more:
    www.webopedia.com/TERM/N/Nyquists_Law.html
    members.aol.com/ajaynejr/nyquist.htm
      Thanks, PeterM
    edited 2006-11-03 17:10
    metron9 said...
    Metron9,
    · They were added to prevent glitches on the pin. Let's assume the output latch is set high and you want to do "LOW pin". If you set the direction first, then set the output you will get a high on the pin briefly.
    Bean.
    edited 2006-11-03 17:12
    If I showed you the full plot you would see varing voltages on the peaks and valleys of the clock wave in the above picture. A 100 mhz scope on a 50mhz clock can only plot 1 point for high and one point for low so that's where I was thinking the Nyquist theorem comes in. No way to see the actual square wave without a faster scope because you need more points in the measurement. I really thought that was the crux of the theorem. i shall have to read it again.
    50 mhz is 50 million cycles so the transition from high to low is only 10ns and the transition from low to high is 10ns, true it is measureing 50mhz and I see the output on the scope but a 100mhz clock cycle I dont think I could see on a 100mhz scope.
    I have an 80mhz oscillator I can plug that in to see.
  • James NewtonJames Newton Posts: 329
    edited 2006-11-03 18:21
    PJMonty said...
    Metron9,
    Peter is right of course, but I think we should add in one more word: you can read a sinewave signal up to 100 MHz.
    A 100MHz scope may not be able to accuratly display a 100 MHz squarewave signal for example. That is because the squarewave (or anything other than a sinewave) contains harmonics of much higher frequencies inside of it. Most analog designers know that so well they don't bother mentioning it, but us digital people sometimes don't realize it.
    For more on Read/Modify/Write problems (which are a seperate issue) see:
    http://www.sxlist.com/techref/readmodwrite.htm
    For clock information on the SX, see:
    http://www.sxlist.com/techref/ubicom/clocks.htm
    James Newton, Host of SXList.com
    james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
    edited 2006-11-04 00:29
    James,
    Salient point. As you climb higher and higher with an analog scope, the displayed signal of a square wave develops rounded corners as the system reaches its limit on handling the harmonics. On my 60 MHz scope, a 50 MHz clock looks just like a sinewave, even though I know it's still a square wave.
    Metron9,
    Still not sure if you have an analog or digital scope. If analog, it's not plotting a point, it's just sweeping the electron beam around on the screen, with all the inherent "infinite" resolution that analog implies. If it's digital, then it is indeed plotting points.
      Thanks, PeterM
    Yes digital storage scope DSO-2102M from Link Instruments I started with an old 20mhz analog scope on its last leg. When I found out how much information I was missing I had to get a better one. It's like a window to another world of time. I know there is another world of gigahertz I am missing out on but I won't get a chance to go to outer space either although I have been called a space cadet before.
