javelin connect lcd-bpi216 — Parallax Forums
archmorearchmore Posts: 2
edited 2006-10-31 16:33 in General Discussion
Hi, i am a tyro using javelin stamp.
i got a problem.
i opened several javefile(BPI216Test, BPI216Demo and BPI216Animation) that i wanted to test LCD-BPI216(#27976).
And i connected javelin stamp to BPI216 step by step with appnote9b operation.
But, the LCD always show "Unrecognizable code".
thanks every forerunner.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2006-10-31 15:03
    Looks like your BPI216 isn't properly configured.
    Check the BPI216 datasheet and setup the lcd for 9600 baud, TTL serial.
    Then try the BPI216Test.java program. It should display "Hello World"
    (without quotes)
    Edit: from the appllication note
    If the output on your display is does not look like that of Figure 9.2, but does display characters of some sort,
    the BPI-216 might be set at the wrong baud rate. Verify that the BPI-216 is set at 9600 baud by checking the
    switch on the back of the unit. The switch marked 24 and 96 should be in the 96 position. Check the users
    manual of your BPI-216 for more information. You will need to power the unit off and back on again for it to
    enter the new baud rate mode.
    regards peter
    Post Edited (Peter Verkaik) : 10/31/2006 3:08:00 PM GMT
  • archmorearchmore Posts: 2
    Hi~peter!
    I checked my baud rate in BPI216Test.java program and the switch position was also right(sw1=off, sw2=on).
    static Uart txOut = new Uart( Uart.dirTransmit, LCD_PIN, Uart.invert, Uart.speed9600, Uart.stop1);
    But the LCD was showed the wrong code again.
    thanks your reply! thank you!!!
