sx52 timers
I am trying to learn how to use the timers on the sx52. I have read a bit on the subject but I am still confused on how exactly you would set everything up in asm to do anything. Could someone either post some simple code to create a pwm signal with a 50% duty cycle using the timers, or reference me to a good link that explains how to work with the timers.
I am assuming he output pin will be rb.6 for timer1, is this correct?
device sx52 IRC_CAL IRC_SLOW RESET initialize FREQ 75_000_000 ;********** ; EQUATES ;********** ;timer1 rT1CPL EQU $00 rT1CPH EQU $01 rT1R2CML EQU $02 rT1R2CMH EQU $03 rT1R1CML EQU $04 rT1R1CMH EQU $05 rT1CNTB EQU $06 rT1CNTA EQU $07 wT1R2CML EQU $12 wT1R2CMH EQU $13 wT1R1CML EQU $14 wT1R1CMH EQU $15 wT1CNTB EQU $16 wT1CNTA EQU $17 ;timer2 rT2CPL EQU $00 rT2CPH EQU $01 rT2R2CML EQU $02 rT2R2CMH EQU $03 rT2R1CML EQU $04 rT2R1CMH EQU $05 rT2CNTB EQU $06 rT2CNTA EQU $07 wT2R2CML EQU $12 wT2R2CMH EQU $13 wT2R1CML EQU $14 wT2R1CMH EQU $15 wT2CNTB EQU $16 wT2CNTA EQU $17 initialize ;load t1 compare register1 with the value of 50 mov w,#wT1R1CML mov m,w mov w, #50 mov !rb,w mov w,#wT1R1CMH mov m,w mov w,#0 mov !rb,w ;load t1 compare register2 with the value of 50 mov w,#wT1R2CML mov m,w mov w, #50 mov !rb,w mov w,#wT1R2CMH mov m,w mov w,#0 mov !rb,w ;do i need to change any of these? mov w,#wT1CNTA mov m,w mov w,#%11000000 ;setup for prescale of 1/128 and pwm mode mov w,#wT1CNTB mov m,w mov w,#%00011101 main jmp mainOUTPUT RB.6 ' Timer1 PWM output pin
TIMER1 PRESCALE, 7 ' 1/128 prescale
TIMER1 PWM, 50, 100 ' Set PWM mode output is on pin RB.6
Then look at the generated code.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
