sx52 timers
I am trying to learn how to use the timers on the sx52. I have read a bit on the subject but I am still confused on how exactly you would set everything up in asm to do anything. Could someone either post some simple code to create a pwm signal with a 50% duty cycle using the timers, or reference me to a good link that explains how to work with the timers.
I am assuming he output pin will be rb.6 for timer1, is this correct?
OUTPUT RB.6 ' Timer1 PWM output pin
TIMER1 PRESCALE, 7 ' 1/128 prescale
TIMER1 PWM, 50, 100 ' Set PWM mode output is on pin RB.6
Then look at the generated code.
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
