USB Servo controller
Recently I have purchased a USB psc with 2 standard servo's.
I hooked everything up accoording the manual and installed the PSCI software ( i have no basic stamp)
But as you can guess nothing works.
servo's are not centering and PSC is not responding on get version command from PSCI software.
I tried the jumper setting, and I'm sure I have enough power (6Volts 3 Amp DC supply)
I do see the servo move a little at power up, but they are not centering.
The green LED is flashing when I change a setting in PSCI, so I guess the virtual serial port is working correct.
But when I press GET PSC VERSION, the response is 'version:...'
Does that mean there is no answer? Can it be that I have to set some baudrate manually? Can it be the driver PIC is not programmed?
thanks for your help
Jacco
Jacco
·· You should contact Tech Support directly on this.· Our phone number is 1-888-512-1024.
Chris Savage
Parallax Tech Support
I also get the "version:..." reply from the Get PSC Version command on the file menu.
Other than calling support, does anyone have a solution?
I really don't want to wait until Monday :-(
John R.
8 + 8 = 10
the conclusion was that the firmware is not programmed. My vendor exchanged the psc for free.
jacco
Thanks for the feedback. That's what I was afraid of. I've got e-mail off to support, and will try calling them after 8:00 AM California time, but don't expect to hear from them until Monday.
I got two of these with a Nomad from CrustCrawler, so I've got CrustCrawler support also on the e-mail. Does anyone know if this will get handled via CrustCrawler or Parallax?
John R.
8 + 8 = 10
·· If you sent an e-mail to support@parallax.com I will see if I can get you taken care of before tomorrow.
Chris Savage
Tom
Tom
This was addressed in another thread. Please follow-up on that thread for assistance.
http://forums.parallax.com/showthread.php?p=632886
Chris Savage
Tom
