Hex translation, I feel pretty studpid but I'm used to the $0F format
Hi,
So, I'm looking at the DataSheet for the Max7219 on page 7 under No-Op Register(because I'm having a lot o problems trying to daisy chain to Max7219 ics) where it says ,"....send the desired 16 bit word, followed by three no-op codes(hex X0XX).
is HEX X0XX just 0
I know its a stupid question, I'm just trying to cancel out all the possible reasons I can't seem to daisychain the two ICs.
Thanks to everyone for putting up with it.
Jeff
is HEX X0XX just 0
Jeff
I would ASSUME that X0XX means that the first, third and fourth digit can be anything as long as the second digit is a zero, that is considered a no-op. If that is the case then, yes 0 would be a no-op. You are sending 16 bits for the no-op right ?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Thanks alot for taking the time to reply to such a silly question...and no I'm pretty sure I wasn't sending 16 bits for the no-op. Thanks again for the kicking me in the right direction.
Jeff
