Hex translation, I feel pretty studpid but I'm used to the $0F format — Parallax Forums
Jeff AltenJeff Alten Posts: 7
edited 2006-10-28 03:28 in General Discussion
So, I'm looking at the DataSheet for the Max7219 on page 7 under No-Op Register(because I'm having a lot o problems trying to daisy chain to Max7219 ics) where it says ,"....send the desired 16 bit word, followed by three no-op codes(hex X0XX).
is HEX X0XX just 0
I know its a stupid question, I'm just trying to cancel out all the possible reasons I can't seem to daisychain the two ICs.
Thanks to everyone for putting up with it.
Jeff
  • BeanBean Posts: 8,129
    edited 2006-10-25 17:49
    Jeff,
    I would ASSUME that X0XX means that the first, third and fourth digit can be anything as long as the second digit is a zero, that is considered a no-op. If that is the case then, yes 0 would be a no-op. You are sending 16 bits for the no-op right ?
    Bean.
    "People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
  • Jeff AltenJeff Alten Posts: 7
    Bean,
    Thanks alot for taking the time to reply to such a silly question...and no I'm pretty sure I wasn't sending 16 bits for the no-op. Thanks again for the kicking me in the right direction.
    Jeff
