Best Way to Fab a PCB
Hey Everyone,
I've been working on a few projects for a company that are finally (
) ready for production.· Quantities won't be to big (maybe 25 a year).· We can have ExpressPCB do it for around $7.00 a board (if we buy 50), but I'd like to FAB the boards myself.· Is it possible to get good quality from stuff like tonar transfer?· If so, how?· The smallest traces are 20 mil, the board is 2.5 x 3 inches.· I've heard the stuff from "Pulsar" works well, does it?
NerdMaster
For
Life
) ready for production.· Quantities won't be to big (maybe 25 a year).· We can have ExpressPCB do it for around $7.00 a board (if we buy 50), but I'd like to FAB the boards myself.· Is it possible to get good quality from stuff like tonar transfer?· If so, how?· The smallest traces are 20 mil, the board is 2.5 x 3 inches.· I've heard the stuff from "Pulsar" works well, does it?▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
NerdMaster
For
Life
I have used the Pulsar kit and I like it alot. It works very well.
Now I have an LPKF PCB milling machine, so I don't have to mess with the chemicals and stuff.
Let me know if you interested in me making you a small quantity of boards (10-12).
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Post Edited (Bean (Hitt Consulting)) : 10/18/2006 4:18:28 PM GMT
Of course, you are limited to single or doublesided boards - no multilayer! I try to minimize through-plated holes by using component holes as vias and solder the component on both sides. If that's not possible, I use very small holes and thin wires (e.g. strands of AWG22 or 24 stranded wire) as my connection between sides.
Use clean blanks and sufficient heat to transfer the patterns (I bought one of the laminators recommended by Pulsar and modified it according to their instructions - it works like a charm and the modification was easy!).
For best results also use the GreenTRF to fill in all the imperfections. I found that it improves the results dramatically and is well worth the money and extra time.
Baer
NerdMaster
For
Life
You need to modify a different laminator to do 0.062" thick boards.
Bean.
Also, the use of the etchant by sponging as opposed to soaking is highly recommended----saves time and chemicals.
My only caution is to not try to get ultra thin traces; at least until you've found a really good photocopier that gives consistent solid coverage. I agree that the green overlay material is worth the effort.
Cheers
Tom Sisk
http://www.siskconsult.com
The place I work for has, like a $5000 copier, so thin traces shouldn't be a problem.
Thanks Again
NerdMaster
For
Life
When I got into it, Pulsar recommended buying a GBC HS200 or HS300 Laminator. Since I use 0.062" boards, I did need to modify it. The step-by-step instructions from Pulsar tell you how to do it and no extra parts are needed. You just have to switch a couple of parts to be able to handle the extra thickness and reduce the speed a bit. It was really very easy and worked perfectly at first try.
I usually run the boards through 2 or 3 times to make sure. You also have to give it a bit of time on start-up to make sure the temperature is high enough (a red light in the laminator goes off when you reach operating temperature).
Baer
http://www.pulsar.gs/PCB/a_Pages/4_Products/4d_Toner_Applicator/Toner_Applicator.html
You will need to download both, the instructions and the photos.
Baer
